What type of motor oil should I use
Discussion in 'Ask An Owner Operator' started by PacManTrap, Mar 8, 2016.
  1. PacManTrap
    PacManTrap Light Load Member
    112
    120
    Jan 29, 2016
    Maryland
    I have a 2001 Peterbilt 379 with a c-12 cat engine with 935,000 miles. Looking for recommendations on what's the best type of oil to use for that year motor. Also any suggestions on preventive maintenance or things I should look for with this particular motor? I've had it on the road for 2 days now and it's running good. Only thing I see is a little blow by and a small drip around the drain plug.
  3. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,982
    18,763
    Mar 9, 2014
    In a van down by the River.
    Id use Shell RotellaT. Seems to industry standard
  4. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    First and foremost, if it's dripping out the drain plug you're threads are probably screwed on that hole. Not uncommon.
    I've had good luck running Mystic and a little Lucas in old motors.... only problem being it's not readily available. Honestly, though it's a Chevy Vs. Ford argument and will come down to personal preference.
    It'll all work so long as you keep up on the maintenance.
  5. Derailed
    Derailed Road Train Member
    2,383
    2,657
    Dec 10, 2008
    Upstate NY
    My 01 c15 has had Rotella t 1540 ran in it from day 1. Has 920 on the clock. Rods and mains looked new when they were rolled. I've been tempted to try Schaefer synthetic blend for easier winter starts and all the other pros I hear about it.
  6. sbaumann14
    sbaumann14 Road Train Member
    1,222
    1,415
    Sep 1, 2010
    Rhinelander, WI
    X2 on Chevy vs Ford. at 935k on a Cat, you're lookin at an inframe here real soon. for piece of mind, spend the $300 and have a dyno run performed and also pull an oil sample and send it into a lab (don't do it at Speedco or some other lube/oil change place as your results will be diluted from the previous persons results). all this will give you a good ides as to what's going on internally.
    I have no preference on oil.... I have a Volvo D-12 with 1.2 on the clock, same original injectors, turbo, bearings...ect. I use Delvac, and change every 12-14k
    Terry270 and Cottonmouth85 Thank this.
  7. truckthatpassesyouby
    truckthatpassesyouby Road Train Member
    1,876
    6,124
    Jun 3, 2015
    Pick the bottle that looks the prettiest.
    Eeyore05 and Cottonmouth85 Thank this.
  8. truckthatpassesyouby
    1,876
    6,124
    Jun 3, 2015
    What rating does your Mystic have
  9. 77fib77
    77fib77 Road Train Member
    10,488
    65,533
    Jul 7, 2010
    St Louis
    I have thrown a gallon of synthetic oil during the winter for easier starts. Dont know if it matters. IMO just change it frequently.
  10. Cottonmouth85
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    Meets or exceeds if i remember right. Used it in an old Detroit S60 but that was years ago.
    New ISX gets Delvac 15-40.
