I know my aluminum stepdeck will take a 45k coil without issue, but that's centered over the frame.
Would a 45klb wheel loader be a problem, since it's on the outer edges? I do have knee braces every 5-6ft. And steel frame
Wheeled equipment on aluminum decks..
Discussion in 'Flatbed Trucking Forum' started by RollinThunderVet, Aug 30, 2019.
Page 1 of 4
How close are the cross members.
Make and model of trailer?
With knee braces I would transport it.
As long as the wheels stay inside footprint of your deck.G13Tomcat Thanks this. -
Knee braces at every 6ft
Tires would extend passed the deck 4in on each side -
How close are your cross members.
The little I beams that run perpendicular to your main beams. The parts your deck is fastened to. -
4" over. You need oversize permits, you might need signs, flags and warning lights.
Depends which states you're running. Holiday weekend you might have curfew restrictions and not be able to run.Last edited: Aug 30, 2019
Lepton1 Thanks this. -
Art Vandelay, starmac, Oxbow and 3 others Thank this.
somewhere in your literature for your trailer it will say X amount of weight in X amount of feet.
a 45k wheel loader is considerably larger and more stretched out than a 45k coil.D.Tibbitt Thanks this. -
It'll haul it all day long. Load er up and put it in the wind driver.
D.Tibbitt, Lepton1 and RollinThunderVet Thank this. -
starmac, Jacoooooooo and RollinThunderVet Thank this.
Granted its spread over 4 contact patches, but my concern was the weight being on the outer edges...Lepton1 Thanks this.
Page 1 of 4
