where to mount bypass on 780 with d13
Discussion in 'Volvo Forum' started by gbrown, Jul 24, 2013.
what a reason to add filter?
Ant 1 so I can extend oil drains and keep oil cleaner longer.
Doesn't make much sense, imop a waste of $$; we have 3 oil filters on D13, keeps oil clean; I did many oil analyzes , free package with oil change @ Speedco after 25-30,000 miles and oil was ok.
I pull my own sample and send it to Blackstone labs, and the difference is.... Speedco test lists soot% as unavailable, might be due to high water or soot in oil....yikes! change it, right?? Good thing I'm in the bay here at Speedco...
Send it to Blackstone, same oil, water less than 1 ppm, no coolant, no fuel in oil, soot% less than a half of a percent....
Blackstone gives you a detailed analysis/opinion, Speedco?
They give you a paper with some info on the back and you're left on your own to try and figure it out...
I would never use Speedco for an analysis again.
It's not that hard to pull your own sample, and Blackstone isn't going to be changing your oil, so they have no interest in giving you an erroneous UOA...
Just fyi.
You're right about the D15, it does a really good job of filtering oil, that's why the OEM interval is set at 50k....
But, if you added a bypass unit you could extend that interval out another 20k, I would think...maybe more, but really, beyond that you start running into shearing and oxidation issues....
The bypass units really shine on the older motors, like the 60
Bypass and top shelf oil will allow you to double the OCI on a 60
If I had a D15 I'd add a bypass, they are unsurpassed in their ability to clean the oil.... but it might just be a feel good thing with that motor, but hey, I like to feel good about my equipment. -
I know Rutherford pushes the OPS, but as far as I'm concerned you can't overservice an engine.
