Where to rent a jeep dolly or booster for trailer
Discussion in 'Heavy Haul Trucking Forum' started by AFC, Nov 24, 2025.
  1. AFC
    AFC Heavy Load Member
    889
    1,177
    Jan 1, 2024
    Has anyone rented a jeep or a booster axle for their trailer? If so, where? Cost? Rental options: as in do they hook the booster to your trailer? If a nationwide service can I drop it off to their location in another state? Finally: just need the option to have an 8 axle setup. Currently I have a 7 axle setup.
  3. Rontonio
    Rontonio Road Train Member
    6,510
    48,147
    Aug 9, 2009
    you don’t have enough neck for a jeep and your trailer is likely not reinforced to safely. Run a booster.
    plus you skill set does not support the use of either ….
    why do you insist on making every single possible mistake while tryinh to do work you are not qualified to perform?
    that 40 ton trailer is not rated for weight you are clearly trying to show horn onto it.
    let me guess you are trying to haul 80k plus stretch loads…
  4. Rontonio
    6,510
    48,147
    Aug 9, 2009
    My guess is you do not know why a jeep won’t add capacity to your particular set up.
    kylefitzy, Feedman, lynchy and 8 others Thank this.
  5. IH Truck Guy
    5,053
    58,826
    Mar 2, 2008
    Purgatory
    Sergio 2.0...............
    LMFAO
    Feedman, TripleSix, lynchy and 8 others Thank this.
  6. truckdad
    truckdad Road Train Member
    2,078
    17,241
    Dec 14, 2014
    Penn Valley, CA
    He needs a jeep and dolly so he can move scrapers. It’s a good combo to break into heavy hauling….
    Feedman, Sons Hero, cke and 7 others Thank this.
  7. AFC
    889
    1,177
    Jan 1, 2024
    Of course not. I wouldn't ever try to do that. I was just trying to do a 93k battery all dimensions legal except weight. My trailer is 45ton.
  8. AFC
    889
    1,177
    Jan 1, 2024
    My trailer will be scraped:)
  9. AFC
    889
    1,177
    Jan 1, 2024
    Saw some his stuff discussed on this forum. You gotta give it to that Canadian he was creative and did it his way!
  10. nikmirbre
    nikmirbre Road Train Member
    5,606
    10,411
    Jul 27, 2011
    High Point NC
    Ive heard guys putting extra weight(over the capacity rating of the trailer) on their trailer..... That's not something I would recommend.
    cke Thanks this.
  11. AFC
    889
    1,177
    Jan 1, 2024
    I kind of understand. Of course I have zero experience and I don't know the nuances. I have read some of your guys posts from 7 years ago and y'all have been discussing this then! All angles have been worked out on this forum and please be patient with me! Don't want to trigger anyone!
