Whistle / Squeal When Turbo Boost is High
Discussion in 'Volvo Forum' started by nutcase, Mar 8, 2014.
  1. nutcase
    nutcase Light Load Member
    259
    100
    May 2, 2010
    Meridian, ID
    I have 2014 Volvo with a D13 engine. When the boost gauge gets up to about 30 I hear a high pitched whistle or squeal. I have tightened all the clamps around the turbo and the charge-air system but no change.
    Any ideas or suggestions regarding the cause and a fix?
  3. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Did you check the Hose for cracks or splits? I had one that split along the internal wire.
  4. 8thnote
    8thnote Road Train Member
    1,980
    3,687
    Aug 12, 2013
    Chattanooga, TN
    I drive a '13 with d13 and I had the exact same problem. A hose on the turbo intake had a split in it and had to be replaced. Mine is a company truck so I have no idea on cost.
    BobcatVolvo Thanks this.
  5. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    I also have a '14 D13, mine only squeals about mid boost range, and when it is cold outside, less than 20 degrees. I tightened all the clamps, have not heard it since, but is is a rare noise.
  6. Flightline
    Flightline Road Train Member
    2,345
    1,165
    Oct 1, 2011
    Almost There
    High pitch sqeal at high boost is a boost leak.
    Could be leaking almost anywhere between the turbo out and even through the head.
    Recently seen one leak at the compressor intake coming off the head.
    These usually show up under extreme cold conditions since fittings shrink with extreme coldness.
  7. R.Hagar
    R.Hagar Medium Load Member
    327
    166
    Apr 2, 2015
    My new 2015 just started doing this... Any ideas where to start? I tightened all the clamps and still can't find anything
  8. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    Look at the two blue hoses on the pipe between turbo and the air to air, you will see black permanent clamp on thoses hoses often we need to cut them and install (tightening) clamps.
    Under load that pipe come up to 300 degree farenheith after a while the clamping load of the permanent clamps is partially lost and a small leak occur and the hissing noise start.
    Ben
  9. R.Hagar
    327
    166
    Apr 2, 2015
    Exactly what I was thinking... Thanks.
  10. benrab
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    Suggestion: Be carefull with the wheel-cut grinder to make sure to don't touch the hose, also in the Volvo parts system they will give you a replacement part number for the clamps, make sure after installation the end of the clamps is not touching their own stopper (because they are a little bit to big (clamp)
  11. Offroadjack
    Offroadjack Light Load Member
    197
    52
    Jun 19, 2012
    I had mine do the same thing. it was the small 2 inch hose on the egr cooler pipe
