Why are most flatbed tie down points rated so low?
Discussion in 'Flatbed Trucking Forum' started by Jesse45, Dec 17, 2015.
  1. Jesse45
    Jesse45 Bobtail Member
    4
    Looking at buying a drop deck trailer and the ones I have seen have the stake pockets or pipe chain spools rated at 5,000 or 5,400 lbs. Most people I have seen on a flatbed use 3/8 chain rated for 6600 lb. why do they make the trailer anchor point the weak link? Are there any options for stronger tiedowns?
  3. Rooster1291979
    Rooster1291979 Road Train Member
    1,308
    1,751
    Sep 4, 2012
    NOLA
  4. TripleSix
    129,370
    Heavier duty trailers will have much stronger tiedown points, but thats also a much heavier trailer too.
    281ric and peterbilt_2005 Thank this.
  5. Jesse45
    4
    and 2 chains - or does that count with one chain wrapped around them? as far apart as they are you really would only be pulling on one no?
  6. Jesse45
    4
    I am not planning on hauling nothing crazy heavy but it just seems like a weird rating halfway between a 5/16 and 3/8 chain
    if your trailer has 5000 pound points might as well use 5/16 chain and lose 300 lb per point but save the weight of handling the bigger chain
  7. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    Use 5/16" G70 chain. Less expensive and easier to handle. Unless you've got the more expensive trailer with the heavier rated tie downs, it's pointless to use the 3/8" chain.
    peterbilt_2005 and MJ1657 Thank this.
  8. Mattflat362
    Mattflat362 Road Train Member
    2,696
    5,723
    Feb 18, 2015
    Avon Lake, Ohio
    I have been meaning to start a thread like this. I am hauling fairly light stuff but I would like to know what experienced guys think of my flatbed straight truck set up. I bought it used and it is nothing like the flat I ran as a company driver.
  9. mpd240
    mpd240 Road Train Member
    1,540
    3,623
    Sep 17, 2011
    Minnesota
  10. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Because, despite you seeing most people using 3/8" chain, most flatbed drivers only every use 5/16" chains.
    Diesel Dave and peterbilt_2005 Thank this.
  11. Junkyarddog5958
    Junkyarddog5958 Light Load Member
    241
    189
    Nov 12, 2015
    We used 5/16 g70 chain. I was buying 2 25 footers for $75 delivered I think. It's been awhile.
