inside tire wear on wide base tires, front drive axle ... recent 3 axle alignment, new wheel bearings and new power divider, shocks little over year old ...
currently at tire shop getting the drives rotated front to back on same side ... did i do alignment a wee bit too late or something else i need to look into?
wide base tire wear
Discussion in 'Trucks [ Eighteen Wheelers ]' started by joecitizen, Sep 6, 2016.
Did you have the tire shop dismount tire an put it back so wear is on out side now? the wheel bearings need to be ck. for end play before mounting next set of tires
joecitizen and BoxCarKidd Thank this. -
I second the wheel bearings notion. There's a specific procedure for setting the preload. You might check the MD Alignment website.
joecitizen Thanks this. -
What off set wheels are you running ? Looks like axle flex? 2 inch off set as ment to be used are a bad design . Flip them around they work fine.
KB3MMX Thanks this.
