Window tint between Houston and Tampa
Discussion in 'Ask An Owner Operator' started by sbaumann14, Feb 24, 2020.
  1. sbaumann14
    sbaumann14 Heavy Load Member
    960
    770
    Sep 1, 2010
    Rhinelander, WI
    Anyone know of a window tint place for big trucks between houston and tampa?
  2. 86scotty
    86scotty Road Train Member
    1,284
    2,296
    Aug 27, 2017
    Appalachia
    Same as any one for little trucks. Call and see if they can help you.
  3. sbaumann14
    960
    770
    Sep 1, 2010
    Rhinelander, WI
    Think I'll wait until i get home
  4. FLtoOKBound
    FLtoOKBound Heavy Load Member
    836
    2,600
    Jan 27, 2020
    West Central, FL
    If you are gonna be in Tampa, I saw a TT at a tinting place in brandon, right off of HWY 60. It was parked on the side right in front with room. FYI
  5. Midnightrider909
    Midnightrider909 Road Train Member
    2,290
    9,370
    Oct 26, 2016
    Get the lightest tint or you will attract attention at the coops.
  6. HoneyBadger67
    1,395
    2,882
    Dec 15, 2018
    Champaign, IL
    If it's just for your doors, do it yourself and save some money. I had my car done by a tint shop but only because it seems every piece of glass is curved. Flat glass is a piece of cake. There are only two rules...
    1: leave a bare edge at the top to keep it from peeling where it goes into the weather stripping.
    2: make sure you get the film inside the bottom weather stripping for the same reason.
    Windex is the perfect lubricant for sliding the film into place.
    Don't use anything with a sharp edge (credit card) to smooth the film out.
  7. sbaumann14
    960
    770
    Sep 1, 2010
    Rhinelander, WI
    I might just give it a try this weekend
  8. sbaumann14
    960
    770
    Sep 1, 2010
    Rhinelander, WI
    Thanks...will google earth it
  9. HoneyBadger67
    1,395
    2,882
    Dec 15, 2018
    Champaign, IL
    The worst thing that could happen is you'll be out $25. You'll have something to do while not moving, though.
  • Draft saved Draft deleted
