i never set my trailer brakes since it's been frozen. But every time I wake up the brakes are popped out, is this normal?
Winter brakes
Discussion in 'Questions From New Drivers' started by roscold90, Jan 16, 2018.
Oh, and continue your practice of not setting the trailer brakes in the winter when parking on flat ground in a parking spot to rest.Lepton1, jammer910Z and Oxbow Thank this. -
You never set trailer brakes, but you go to bed, wake up and shes popped.
The only reason on earth for it to pop is that your air supply dropped low enough to pop em somewhere.
Another thought would be a defect in your valving inside that dash of the tractor, whatever it is... but it's not a common problem.BUMBACLADWAR Thanks this. -
Most red buttons will "pop out" whenever the air pressure falls below about 40-50 psi
Lepton1 Thanks this. -
x1Heavy Thanks this.
Trucker61016, Lepton1, Oxbow and 1 other person Thank this.
Not uncommon to occur in the cold. The good news is that by the time this occurs the brakes and everything should have cooled all the way down by then so you probably would not have an issue with frozen brake pads.
Justrucking2 and x1Heavy Thank this. -
Leave the truck running... so it will keep the air up. Everything else will be nice and warm.
LoLLepton1 Thanks this. -
Trucker61016, Justrucking2 and Hulld Thank this.
Alright. Thanks guys
