Winter clothing recommendations for tanker, flatbed and heavy haul?
Discussion in 'Questions From New Drivers' started by stacks, Oct 13, 2026.
  1. stacks
    stacks Road Train Member
    1,558
    861
    Oct 27, 2011
    Emerald Isle
    What’s everyone wearing that relates to job type tanker flat deck heavy haul drivers are out in the Elements a lot more than Reefer or dry van , I’ve been using Carhartt now for the past 7 years with no complaints there products Aren’t cheap but for thermal long johns and vests just get regular store bought I got some good bargains at Walmart last fall even dickies long sleeve t shirts cheaper than Carhartt maybe the material didn’t feel as thick but so far seem to be doing the job , as for Emergency rations tinned soup beans ravioli one of those camping stoves if unfortunately get caught out stay safe.
    OldeSkool and Carpenter Scotty Thank this.
  3. tscottme
    tscottme Road Train Member
    Sounds like you have the situation under control. I did recently get USB hand warmers those are fantastic for outside work. $20-30 from Amazon. Much nicer than the hot hands chemical hand warmers and they have 3 levels of heat. I think they last a few hours at low setting. Anything with a flame used inside is as likely to set your truck on fire as cook a meal. My last few trucks had inverters so microwave is good as long as truck or APU works.
    Also, I discovered snow pants and snow jacket are great, water proof and lots of loft keeps you warm through body heat, if you aren't doing hard work.
  4. Ddh77777
    Ddh77777 Medium Load Member
    494
    987
    May 28, 2025
    Mustang survival float coat, grundens Neptune pants, xtratuf boots. That's what I wore in alaska, and it is undefeated.
    It ain't cheap though.
  5. PianoManCJS
    PianoManCJS Medium Load Member
    439
    445
    Jan 13, 2025
    Carhartt pants, but the darn ABLOY cargo trailer door enforcer locks chew right through the pockets...so now I carry the padlock in my hand when walking to tye back of the trailer...so even though Carhartt is rugged and tough, it'll still shred.
  6. 86scotty
    86scotty Road Train Member
    4,931
    13,677
    Aug 27, 2017
    Appalachia
    Check out Key Apparel. They've got some excellent work duds, winter insulated stuff, hi vis stuff.
    I've ordered a lot from them since I found out about them.
    No affiliation, just a fan.
  7. fromAtoZ
    fromAtoZ Light Load Member
    267
    642
    Sep 19, 2026
    Phoenix
    Ariat work boots, top and bottom thermals, jeans and t-shirt, hoodie, Frogtoggs raincoat, REI rain pants, knit hat or trapper style hat, snowboarding velcro face mask, knit gloves, leather gloves, wool socks, Plumber's torch for frozen locks, frozen winches, frozen 5th wheel jaws.
    If you're outside in high winds and sub-zero temps. Get a smowmobile suit and heavy insulated snow boots. A wool scarf for your neck helps too.
  8. Espressolane
    19,871
    127,081
    Silk and silk-wool blend base layer pants and shirts, sock liners too. Be surprised how well they work. Not bulky, easy to layer with. They can be pretty pricey for good quality, but they last a long time. Have a few sets that are quite a few years old and still going.
  9. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,068
    2,310
    Dec 15, 2021
    Xxtratuf insulated in fresh snow,good for -10,Sorel boots if colder.I bought the Sorels in 1976.
  10. Carpenter Scotty
    Carpenter Scotty Road Train Member
    2,197
    26,582
    May 11, 2025
    Montreal
    I go with merino wool for the under layers, back country snowboarding shell bibs on the outside layer, and these for boots, there good to-70f if needed, a bit bulky, but great in the cold and on ice. IMG_1851.jpeg
    Added, leaves flexibility on the amount and kind of in between the two layers. Important to not get sweaty, that’s what can do in your workday outside in the cold
    Reason for edit: Added
    '88K100, OldeSkool, stacks and 3 others Thank this.
  11. Crusader66
    Crusader66 Road Train Member
    2,699
    70,676
    Oct 21, 2016
    Anything wool and learn how to layer.
