Wiring harness damage right after alternator/battery replacement
Discussion in 'Freightliner Forum' started by jingle188, Jul 2, 2026.
  1. jingle188
    jingle188 Bobtail Member
    Hi all, looking for some outside perspective on a repair dispute.
    Background: I have a 2020 Freightliner M2 (company truck). It went into a shop (Peach State Truck Centers, Norcross GA) for an alternator and battery replacement. Shortly after picking it up, we started having issues, and the shop diagnosed it as wiring harness damage on a follow-up visit. The estimate for this second repair is significantly higher than the original alternator/battery job.
    The shop is not accepting any responsibility for the harness damage, and is treating it as a completely separate, unrelated issue.
    My questions:
    1. In your experience, how likely is it that harness damage showing up shortly after an alternator/battery job is actually caused by the shop's work (e.g., improper reinstallation, harness rubbing against something after being moved, incorrect wiring causing overheating)? Or is this a common coincidence with a truck this age/mileage?
    2. What's the best way to push back on a shop that's denying liability? Any advice on documentation, questions to ask the service manager when I go in to discuss this with them?
    Any input from mechanics or fleet/owner-operators who've dealt with something similar would be really appreciated. Thanks!
  3. bjytech
    bjytech Light Load Member
    249
    225
    Nov 9, 2013
    The harness damage described in the work order has nothing at all to do with any work that would have been done changing the alternator or batteries. The current problem with the truck is its own separate issue.
  4. QUALITYTRUCK
    1,821
    1,789
    Jun 14, 2009
    romulus,mi
    The "wiring damage" was more than likely the original issue. I am guessing that you had a charging issue?
    bjytech, 062 and Big Road Skateboard Thank this.
  5. 062
    062 Road Train Member
    6,414
    34,286
    Oct 20, 2013
    There are a couple of rub points that are in that area and if the truck has been overheated I’ve seen the harness melt at the front of the head.
    It looks like you don’t have any can bus codes, so it would be easy to repair or run an overlay.
    QUALITYTRUCK Thanks this.
