Yanmar track hoe excavator??
Discussion in 'Heavy Haul Trucking Forum' started by kurbski, Nov 23, 2013.
  1. kurbski
    kurbski Light Load Member
    284
    644
    Jul 6, 2008
    NE Florida
    A friend of mine purchased a Yanmar track hoe that caught on fire. He needs to winch it up on a trailer. Does anyone know how to unlock the rubber tracks so it will roll freely?
  3. Flightline
    Flightline Road Train Member
    2,344
    1,167
    Oct 1, 2011
    Almost There
    I don't beleive there is an unlock as there normally are hydraulic motors. Might be able to tie into the system with a portable hydralic pump.
    kurbski Thanks this.
  4. wore out
    wore out Numbered Classic
    18,168
    230,051
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Take the outside plate off final drives. Should be a row of 8 to 10 fairly small bolts to remove plate. In the very center of final drive is a round gear with a small shaft on it (axle) remove it. Be sure machine is scotched as removing both sides it freewheels at all times. I have hauled several bigger machines that way just chain it down good.
    Cetane+ and kurbski Thank this.
  5. kurbski
    284
    644
    Jul 6, 2008
    NE Florida
    Ok I'll pass it on. I'm a tanker yanker and don't do heavy haul. Thank you both for the replies. It's a one time deal and he's on a limited budget so I really appreciate it.
  6. wore out
    18,168
    230,051
    Jun 5, 2013
    These bolts should be the farthest outside row not the ones that hold sprocket to final. If any questions pm me and I will talk you through it I have been an equipment mechanic for 20 years just trucked part time till a year ago. Be glad to help.
    kurbski and dannythetrucker Thank this.
  7. wesland24
    wesland24 Medium Load Member
    343
    154
    Dec 15, 2006
    Macon,GA
    Perfect example of what this forum is meant for informative helpful and to point no whining, complaining or fussing about ones grammer
    281ric and Fatboy42 Thank this.
