Yard Move Work double axle T2000, will it handle the weight?
Discussion in 'Heavy Haul Trucking Forum' started by zmster2033, Dec 12, 2018.
  1. zmster2033
    zmster2033 Light Load Member
    181
    225
    Apr 28, 2011
    Charlotte, NC
    A buddy of mine that works at a sandblasting company reached out to me about potentially handling some yard moves for them. I have a double axle T2000 that I use to pull a dry van on a regular basis and handles 80,000 gross just fine. The unit in question is an 85,000# air chiller on a tri-axle RGN trailer. If they are wanting me to move this 200 feet forward and then back it up 200 feet when done, would you all be concerned in using my T2000 tractor to handle this? What are the odds something on the suspension gets damaged? Trying to get some input from the heavy haul guys as you all are much more versed than I in this segment.
  3. uncleal13
    uncleal13 Road Train Member
    3,757
    6,199
    Apr 9, 2009
    Humboldt, Sk
    No problem, just take it slow, don't reef on it.
    I hauled 140,000 lbs for two years with a truck that was only rated for 80,000. But the front diff bearings did give up after that much work.
    Oxbow and zmster2033 Thank this.
  4. buddyd157
    buddyd157 Road Train Member
    13,456
    34,354
    May 25, 2017
    under a shade tree
    i'd do that......
    Oxbow, Puppage and zmster2033 Thank this.
  5. ZVar
    ZVar Road Train Member
    10,911
    23,805
    Sep 10, 2010
    Flint, MI
    A little story on how overbuilt most tractors are...
    At my last job we got a tractor in that in a previous life was a single axle daycab. It got a frame extension and a second axle. Office (I hope randomly) chose this tractor to do heavy loads. It got plated for 105,000 lbs and pulled a quad axle trailer for I know of at least two years. The weld from the frame extension finally broke after several winters in MI ate away at it. The drivetrain was still strong.
    Keep it in low, move slow and steady and you will be fine. Also when you drop it, make sure it's supported by more than asphalt. Seen several quad axle trailers break through even 6 inch thick asphalt.
    misterG, Rugerfan and zmster2033 Thank this.
  6. zmster2033
    181
    225
    Apr 28, 2011
    Charlotte, NC
    Appreciate the input! What kind of weight on the drives would you all start getting concerned with? I am not sure how the weight will be distributed between the trailer axles and the drives.
  7. johndeere4020
    8,522
    119,289
    Jan 1, 2010
    Set it on the trailer and pull forward. Is the trailer self contained or do you need a wet line?
    SAR, 4mer trucker and Ruthless Thank this.
  8. zmster2033
    181
    225
    Apr 28, 2011
    Charlotte, NC
    I believe self contained. The trailer has a little motor that powers the hydraulic levers.
  9. johndeere4020
    8,522
    119,289
    Jan 1, 2010
    Welp there ya go, hook er up and pull it forward.
    SAR, 4mer trucker, Oxbow and 3 others Thank this.
  10. 379_largecar
    379_largecar Light Load Member
    55
    111
    Mar 7, 2014
    Louisville, ky
    I have personally had 145000 on a tandem axle dump truck hauling steel alloy(looks like sand) i would load up haul it 3 miles and dump i did that for 2 years and the truck was still decent. I wouldnt even bat an eye at that load. On the flip side of that ive seen my brother wring several driveshafts hauling 75k on the floor of a rgn so dont dump the clutch
  11. Kshaw0960
    Kshaw0960 Road Train Member
    1,575
    4,972
    Jun 17, 2018
    Few years ago I was a yard dog for a large paper company. It was a 1995 single axle international day cab. This thing grossed over 100,000 lbs on the regular between the sheet side and finished product side of the plant. What’s more impressive is we never broke a single 57’ trailer at all.
