05 kenworth T2000 fault code 95
Discussion in 'Kenworth Forum' started by Meathauler, Dec 18, 2011.
  1. Meathauler
    Meathauler Bobtail Member
    Jun 25, 2011
    41
    Thanks Received:
    6
    San Antonio, tx
    Anyone have any idea what the fault code 95 means? My check engine light came on and I checked the code by turning off and reading the blinking engine light. It was 9 then a two second pause and 5. But truck runs normal and all the fluids are full, fuses seemed ok.
  2. cowcatcher
    cowcatcher Light Load Member
    Dec 11, 2011
    58
    Thanks Received:
    12
    Ridin' round with the top down !
    I assume its a CAT engine. 95 code is for the IVA oil psi sensor.
  3. gonzo01
    gonzo01 Light Load Member
    Jun 14, 2010
    74
    Thanks Received:
    5
    denver, co
    be sure to check for oil leaks under the valve covers
