06 losing prime in fuel system
Discussion in 'Volvo Forum' started by majestyk, Aug 12, 2013.
  1. majestyk
    majestyk Road Train Member
    Jun 28, 2009
    1,658
    Thanks Received:
    885
    las vegas, nv
    The truck will run (continues to do so as long as you are moving down the road) after I hand prime it but goes dead after idling for a few minutes. When manually pumping it fuel with air bubbles come out of the hole next to the pump. Any suggestions on what needs to be repaired? Thanks very much for the help.
  2. PST
    PST Light Load Member
    Sep 7, 2009
    125
    Thanks Received:
    53
    USA
    Air bubbles means it is sucking air. Check for rubber bits and pieces in fuel filters/housing, if so you will need to replace fuel line. if none, with the motor running you can take a can of starting fluid and spray around fuel line/filter mating surfaces and if a leak is found the motor should rev-up.
  3. JR OTR
    JR OTR Light Load Member
    Jan 13, 2009
    272
    Thanks Received:
    198
    This happened once to me earlier this year, problem was the rubber gasket on the secondary fuel filter not being seated quite right and allowing air in. Did this happen immediately after a PM? That is what happened to my truck. Good luck, Jim
  4. majestyk
    Jun 28, 2009
    1,658
    Thanks Received:
    885
    las vegas, nv
    Thanks guys will check on those things. Yeah pretty much started right after a PM.
  5. Moneymike
    Moneymike Light Load Member
    Apr 17, 2013
    118
    Thanks Received:
    31
    Bad fuel filter or separator. Like someone said air bubbles so you are sucking air. Change both again i would say.
  6. VolvoTech0816
    VolvoTech0816 Bobtail Member
    Aug 4, 2013
    39
    Thanks Received:
    8
    fuel/water seperator has a check valve on the front side that sticks open pretty common. also if ou have leakage at the cups that can cause air in fuel issue, check out that valve first, then have the clear lines hooked up to the front of the head and check out the cups.
  7. Moneymike
    Apr 17, 2013
    118
    Thanks Received:
    31
    If injector cups leak you are gonna get fuel in your coolant tank also.
  8. majestyk
    Jun 28, 2009
    1,658
    Thanks Received:
    885
    las vegas, nv
    Problem got a little worse as it stopped on me while driving. Had someone check it out by putting some pressure on the fuel system and found the leak. Was coming from a line just behind the manual pump toward the cab. Hoping it holds out enough to make it back to the yard tomorrow to get it replaced.
  9. rick3305rick
    rick3305rick Light Load Member
    Sep 18, 2013
    50
    Thanks Received:
    21
    This will not make the engine rev, your thinki
    THIS WILL NOT MAKE A DIESEL REV, your thinking of a car with a gas motor and that only works a the vacuum lines.
  10. DieselDog38
    DieselDog38 Bobtail Member
    Oct 3, 2019
    5
    Thanks Received:
    I am having issues finding where the air is getting in on a 2012 Mack CXU613 MP8. Any tips or advice?
