06 T800 C15 Insterment cluster proplem
Discussion in 'Kenworth Forum' started by RMT, May 24, 2015.
  1. RMT
    RMT Bobtail Member
    Jan 4, 2014
    Thanks Received:
    I have a 06 T800 C15 with instrument cluster problems. With the key off you see odometer and trip readings with key on there are just - - - - . When engine is running there is no tachometer,oil pressure,water temp,speedometer but the temperature gauge works. Had problems in battery box before checked repairs form before doesn't look like same thing. All fuses that are not breakers are good. Looking for some guidance on what to check next.
  2. WitchingHour
    WitchingHour Road Train Member
    Apr 1, 2011
    3,424
    Thanks Received:
    2,143
    Broomfield, CO
    Could be a CECU issue... you'd need the ESA software to diagnose it.
    RMT Thanks this.
