07 pete 387 c15 vs 09 pete 387 isx
Discussion in 'Ask An Owner Operator' started by captain1703, Feb 19, 2014.
  1. captain1703
    captain1703 Bobtail Member
    Feb 17, 2014
    14
    Thanks Received:
    Pocono, Pa
    I am looking at getting a new truck and need some advise on which truck is going to be better with fuel mileage and reliability. I drive reefer regionally 600 miles a day in pa. I am loaded 300 and empty 300 miles per trip. The 07 peterbuilt 387 has a c15 435 no dpf with 13 speed and 3.55 rears and 22.5 lp tires. The 09 387 has isx 450 with dpf and 10 speed with 3.55 rears and 22.5 lp super singles. Both trucks have apu. Both trucks have the same monthly payment but the 07 has a 10 month shorted term to pay off. Thanks any advice would be appreciated.
  2. captain1703
    Feb 17, 2014
    14
    Thanks Received:
    Pocono, Pa
    forgot to mention the 07 has 630,000 and the 09 has 524,000 miles
  3. Lone Ranger 13
    Lone Ranger 13 Road Train Member
    Sep 27, 2012
    1,542
    Thanks Received:
    1,298
    Asheville, NC
    I hear a dpf can be troublesome. Since you aren't going to CA, the non dpf might be the way to go. It seems the cat acert seems to be dependable. I would take the '07. Good luck.
  4. captain1703
    Feb 17, 2014
    14
    Thanks Received:
    Pocono, Pa
    I also hear that the 08 to 09 are the worst but I don't have a problem with keeping up with cleaning of the egr system and dpf if I can get better fuel milage. I also heard that the 07 c15 is one of bad cats but do not know for sure. A friend has on he has problem with leaks and can only get 6.4 empty.
  5. kw550cat
    kw550cat Medium Load Member
    May 22, 2012
    663
    Thanks Received:
    596
    brooklyn, new york
    The 07 has a 13 which helps on hills. the 3.55s are also decent but I prefer 3.70s because they are more versatile. 07's aren't that bad. Check the serial number on it. That will tell you if its an emissions motor or not. I would need to find the number that specifies this. When i find it I will post it. Early 07 is good, late 07 is bad. If it was me between these two I would take the 07. You should get atleast 6.5 loaded depending upon how you run. I get that in my driving style which is fast and my loads are heavy.
  6. captain1703
    Feb 17, 2014
    14
    Thanks Received:
    Pocono, Pa
    Thanks, I would appreciate the info on the serial #
  7. LBZ
    LBZ Road Train Member
    Oct 22, 2008
    1,771
    Thanks Received:
    1,266
    Road to Nowhere
    SDP is the serial prefix to worry about on that motor. That will tell you it has a DPF/CGI emission garbage set up. NXS is PRE DPF & the route to go if all else is equal in terms of the remaining parts of the truck are good vs the 2009.
    captain1703 Thanks this.
  8. kw550cat
    May 22, 2012
    663
    Thanks Received:
    596
    brooklyn, new york
    SDP is the one to stay clear of. If it has it, then dpf is in the motor.
  9. captain1703
    Feb 17, 2014
    14
    Thanks Received:
    Pocono, Pa
    Thanks it has the nxs prefix
  10. bstromback2002
    bstromback2002 Light Load Member
    May 12, 2012
    133
    Thanks Received:
    24
    wi
    I would definitely go with the 2007 but depending on how it was specd when new it may have a diesel catalytic converter on it my 2006 387 c-15 did we had two 07 379's that had them also. Very easy to remove and replace with a piece of pipe.
