07 T600 Kenworth Dash marker and tail lights won't stay on
Discussion in 'Kenworth Forum' started by Chris522, Nov 23, 2014.
  1. Chris522
    Chris522 Bobtail Member
    Nov 23, 2014
    Thanks Received:
    Tyndall,SD
    Fri when I was heading down the road my dash lights just went out along with all but my headlights turn signals still work and brake lights still work but no tail lights on tractor or trailer first thing I checked was my plug in cord it wasn't that I can hear the relay click when they do come on for a split second then they go right back off the marker light fuse gets very hot I also replaced the marker light relay the lights on the hood by the doors do not come on at all does anyone have any idea how to solve this problem?
  2. skateboardman
    skateboardman Road Train Member
    Jan 14, 2012
    6,232
    Thanks Received:
    5,706
    flatbed heaven
    you got a dead short, had that exact thing happen, it was a short on one of the side lights on a utility flatbed
  3. Inland-Pilot
    Inland-Pilot Light Load Member
    Jun 23, 2010
    229
    Thanks Received:
    135
    Jackson, Ms
    Disconnect the trailer cord and narrow it down.
    Chris522 Thanks this.
  4. Chris522
    Nov 23, 2014
    Thanks Received:
    Tyndall,SD
    I did that very 1st
  5. rmdocks
    rmdocks Bobtail Member
    May 25, 2016
    Thanks Received:
    what did you find with that problem?
  6. ShooterK2
    ShooterK2 Road Train Member
    Dec 14, 2012
    5,533
    Thanks Received:
    89,470
    Oklahoma
    Could be a dead short. Could also be a bad ground. My '99 W9 relay got so hot it caused the plastic tabs that hold the wires to the back of the really to fall out inside the fuse box. My solution was to take the dash lights off that circuit (wired them to a separate switch), then switch to all LED lights on truck and trailer (they pull way less amperage). Then I took the fuse box out, took it apart, and re-wired to one of the spare relay spots. No more heat issues since.
    I think it has a lot to do with the age of the truck/wiring. Connections corrode over time and wires get brittle.
  7. Caterpillar_ks
    Caterpillar_ks Bobtail Member
    Apr 25, 2017
    Thanks Received:
    Did you ever find locate were the dead short was? Im having the same problem on my 96 t600. I know i have it in the cab just dont have a idea were to start looking.
  8. justnikki84
    justnikki84 Guest
    Having the same problem with my '04 T600
