07 Volvo VN- "Check Coolant at Next Stop"
Discussion in 'Volvo Forum' started by tleisner, Mar 30, 2012.
  1. tleisner
    tleisner Bobtail Member
    Mar 30, 2012
    5
    Thanks Received:
    Philadelphia,PA
    got a 07 volvo vn tractor with IPC message of "check coolant level at next stop". No fault codes. Replaced coolant level sensor and cleaned coolant tank with same result. Ohm wiring from sensor to ECU connector with no resistance found. Anyone come across this?:biggrin_25524:
  2. Pablo-UA
    Pablo-UA Road Train Member
    Oct 11, 2010
    7,604
    Thanks Received:
    1,642
    Borispol, Ukraine
    on some coolant tanks sensor is just a magnetic switch, floating magnet is inside tank. When tank goes bad, magnet sink ore stuck, so....
    to be sure try to use small magnet to check sensor
  3. tleisner
    Mar 30, 2012
    5
    Thanks Received:
    Philadelphia,PA
    sensor is a circuit board not float
  4. Pablo-UA
    Oct 11, 2010
    7,604
    Thanks Received:
    1,642
    Borispol, Ukraine
    ouh, version-II truck....
  5. Pablo-UA
    Oct 11, 2010
    7,604
    Thanks Received:
    1,642
    Borispol, Ukraine
    do you have fault code with disconnected sensor?
  6. tleisner
    Mar 30, 2012
    5
    Thanks Received:
    Philadelphia,PA
    do not have any fault codes
  7. v6killer
    v6killer Medium Load Member
    Dec 6, 2010
    448
    Thanks Received:
    122
    ChicagoLand
    Your EGR Cooler might be eating some of your cool-it ! Just an though, how many miles are on the truck.
  8. Pablo-UA
    Oct 11, 2010
    7,604
    Thanks Received:
    1,642
    Borispol, Ukraine
    BTW - what engine?
  9. Pablo-UA
    Oct 11, 2010
    7,604
    Thanks Received:
    1,642
    Borispol, Ukraine
    if ISX, there is coolant level unit. Low coolant data via J1708 datalink.....
  10. The Bulkmatic Grasshopper
    The Bulkmatic Grasshopper Bobtail Member
    Apr 4, 2012
    40
    Thanks Received:
    17
    Kentucky
    If it's not "losing" coolant, you should be able to just unplug the sensor and be fine from there
