08 or 07 9900
Discussion in 'Questions From New Drivers' started by 1mm3406e, Jul 13, 2019.
  1. 1mm3406e
    1mm3406e Bobtail Member
    Jul 13, 2019
    28
    Thanks Received:
    13
    So about to become 18 and have the options of picking a 08 or 07 international 9900 both has a 1850 torque isx . The 07 has a 13 speed 18913b 565. The 08 has a 18 18918b with 600. Truck will be hauling building materials that weighs from 40 to 55 ton almost everyday. Any suggestions
  2. FlaSwampRat
    FlaSwampRat Road Train Member
    Jun 1, 2019
    4,900
    Thanks Received:
    17,796
    Valrico FL
    Are you buying it? 18 and set up with the ability and the connection to carry 110,000lb loads? Good on ya. I would get some smaller experience first but I'm not gonna tell you what to do. If I was going to be dragging that much weight if you go for something with an 18 speed just so you have as many options as possible. I would pick a truck with the best RECORDED service history, that's a big deal.
  3. Moose1958
    Moose1958 Road Train Member
    Dec 17, 2010
    15,167
    Thanks Received:
    33,405
    Williesburg, Virignia
    I would make one suggestion. Be more clear about what about to become 18 means. Does it mean your 18th birthday or about to start driving an 18 wheeler.
    FlaSwampRat Thanks this.
  4. Rubber duck kw
    Dec 9, 2017
    6,092
    Thanks Received:
    17,686
    I would go with the 18, but I'm also of the persuasion more gears is better than fewer.
  5. TripleSix
    18,526
    Thanks Received:
    129,755
    The 07.
    08 was the very first year of regen. And I would have sworn that a factory 600 would have come with at the very least, a 20918B.
  6. MartinFromBC
    Oct 19, 2018
    2,769
    Thanks Received:
    12,477
    Get the 07.
  7. 1mm3406e
    Jul 13, 2019
    28
    Thanks Received:
    13
    I’m gonna check again
  8. 1mm3406e
    Jul 13, 2019
    28
    Thanks Received:
    13
    Ok
    Why do you say so, not disagreeing
  9. 1mm3406e
    Jul 13, 2019
    28
    Thanks Received:
    13
    Thanks for the replies my beloved Truckers. I was borned in area with a quarry with trucks n big equipment with my dad being a heavy hauler. Been waiting to become a full time trucking from a toddler.
    Crude Truckin' and FlaSwampRat Thank this.
  10. MartinFromBC
    Oct 19, 2018
    2,769
    Thanks Received:
    12,477
    Correct me if I am wrong, but isn't the 07 DEF free.
