'12 cascadia grinds at idle
Discussion in 'Freightliner Forum' started by Jorihe84, Jan 27, 2013.
  1. Jorihe84
    Jorihe84 Road Train Member
    Sep 1, 2010
    2,763
    Thanks Received:
    1,333
    North Florida
    Been noticing a grinding type noise when idling. It goes away when in gear and just pressing the clutch in. Any ideas?
  2. GrapeApe
    GrapeApe Road Train Member
    Jan 7, 2013
    2,215
    Thanks Received:
    2,211
    Sounds like a clutch release bearing problem. Pull the inspection cover and take look for metal shavings in the bell. It could be a few things. Is it a DD engine? I know they had an issue with the starters getting stuck engaged, which makes a grinding rattling noise, but that would not come and go with the clutch pedal.
  3. Colorato
    Colorato Road Train Member
    Feb 22, 2011
    1,336
    Thanks Received:
    865
    My 13' does this to. Just like on yours if I press the clutch pedal down just a little bit it stops.
  4. Jorihe84
    Sep 1, 2010
    2,763
    Thanks Received:
    1,333
    North Florida
    The '12 Pete I just got out of occasionally did it. I had an APU so rarely ever idled to hear it
  5. jbourque
    jbourque Heavy Load Member
    Oct 25, 2012
    924
    Thanks Received:
    553
    south english iowa
    a clutch bearing will do that, dont know if they still have a grease zerk for them on the newer trucks
