12V Coleman Fuse
Discussion in 'Questions From New Drivers' started by BossOutlaw88, Sep 15, 2012.
  1. BossOutlaw88
    BossOutlaw88 Road Train Member
    Oct 30, 2011
    1,451
    Thanks Received:
    352
    Cali
    I bought 100 of the UL 1/4"X11/4" 7.5A/250V glass type fast acting fuse. I received them in the mail and put the fuse in and it blows every time. What fuse do you use to make it work? I went on the Coleman website and the fuse they used to sell for it is discontinued.
  2. Wayneh74
    Wayneh74 Light Load Member
    Sep 14, 2012
    91
    Thanks Received:
    26
    Greenwood,Ms
    you could always use tinfoil but if there is a problem with you colman it will burn it up.
    BossOutlaw88 Thanks this.
  3. CAXPT
    CAXPT Road Train Member
    Feb 10, 2008
    3,032
    Thanks Received:
    13,351
    If the fuze is blowing, there's a problem. A fuze works by protecting the device from burning out the vehicle because of a defect with the device. Find the problem, fix it, then replace the fuze and see if that doesn't fix it.
    Somewhere in the device, you have an excessive draw that is blowing that fuze. Find it. Fix it. That may mean replacing the fan/cooler assembly.
    Good Luck
  4. chalupa
    chalupa Road Train Member
    Jul 22, 2010
    3,757
    Thanks Received:
    1,643
    Houston,Texas
    And Walmart sells / sold the replacement fan unit.....if you need it.
  5. dannythetrucker
    dannythetrucker Road Train Member
    May 26, 2011
    2,856
    Thanks Received:
    4,032
    everywhere, man
    this is for a cooler that plugs into a cigar lighter ? If so I have had similar trouble and the fault was the end that plugs into the cigar lighter had worn out and gotten hot. It's better to cut it off and hard wire it in to a fuse protected circuit or attach it to cb wiring studs if you have one not being used.
    But like the other guys said it could be the fan, and you definitely want to take it apart and clean up the cooling fins and fan from time to time to keep it running efficiently.
  6. BossOutlaw88
    Oct 30, 2011
    1,451
    Thanks Received:
    352
    Cali
    I've only had this cooler for a month. It's still brand new. I'm just gonna discard it and buy a Igloo 45 quart. I'm done with Coleman.
    CAXPT Thanks this.
