2 speed rears
Discussion in 'Heavy Haul Trucking Forum' started by DMH, Dec 1, 2014.
  1. DMH
    DMH Medium Load Member
    Jan 9, 2012
    344
    Thanks Received:
    110
    Out of curiosity at what weight do you start to need 2 speed rears. I know it's sorta of a loaded question and depends on terrain but iam just looking for a round about answer. Thanks guys
  2. 315wheelbase
    315wheelbase Heavy Load Member
    Oct 26, 2014
    783
    Thanks Received:
    602
    an 18 spd with 3.73 or hight 4.11, 4.33 etc should do OK,,about the only time a 2spd rear helps is getting under the goose neck of a mechanical rgn when goss exceeds 120,000#..I hauled upto 140,000# with just an 18spd and 3.73 rears on tall 24.5 rubber, if you are going to gross over 250,000# might want to look at 2spd rears,,
  3. Pool6710
    Pool6710 Medium Load Member
    Aug 10, 2014
    662
    Thanks Received:
    258
    Minnesnowta
    With that weight arnt you limited to 40-45mph anyways?
  4. Passin Thru
    Passin Thru Road Train Member
    Mar 8, 2007
    1,918
    Thanks Received:
    565
    VA
    In the oilfield you need them. We had a V12 CAT, 13 over, 4 speed Brownie and 2 speed rears. You could put it in low and walk around it at full throttle.
    281ric Thanks this.
  5. 201
    201 Road Train Member
    Apr 16, 2014
    12,621
    Thanks Received:
    25,905
    high plains colorado
    Hi DMH, I think what you mean is, at what weight do you need a 2 speed rear axle. Back in the day, when smaller straight trucks had gas motors or small diesels, anything with dual wheels ( 10x20 or 11x22.5) on the rear usually had a 2 speed rear axle (red button on shifter). Nowadays, with more powerful diesels and automatics or straight 6 or 7 speed transmissions, you don't see 2 speed rear axles as much. As far as weight, I'd say anything over 25,000 lbs. or 30,000 gross, would have a 2 speed.
  6. Oscar the KW
    Oscar the KW Going Tarpless
    May 19, 2011
    12,247
    Thanks Received:
    28,119
    I'm not really sure that there is ever a "need" for them, I can see where they could be really nice though. I know a guy that has them, he had one of the rears go out on him, and the other wasn't far behind. Cost him $19K just to have them rebuilt.
    I would like to have them so I could have a little longer legs when I am empty, and keep my 4.10's or maybe even 4.33's for when I am loaded.
  7. Superhauler
    Superhauler TEACHER OF MEN
    Jan 30, 2010
    12,209
    Thanks Received:
    100,732
    keep stroking.
    ol boy I run with has two speed rears. always braging about how handy they are. I go into the same mud holes as he does with my 4:11's I don't see a need for them running around at 150000 lbs some times. would I have them, probably. but haven't seen a need for them yet for what I do.
    59MackB61 Thanks this.
  8. DMH
    Jan 9, 2012
    344
    Thanks Received:
    110
    Thanks for the replys guys. I certainly dont have a need or desire to haul heavy enough to need them but I was curious. I run 3:55s and a 13 but iam never over 125k gross.
  9. sky_blue
    sky_blue Light Load Member
    Sep 12, 2012
    63
    Thanks Received:
    35
    Tampa, Fl
    I talked to the head mechanic for a huge heavy haul company in the mountains centered around the WV area, mostly their own construction equipment. Ran about 40 trucks vintage 1995-2003, all cat 550's, 18 spd, 2 spd 46k rears with lift axles on tall rubber. Told me two speed rear ends were absolute junk, they were complex to repair and don't last nearly as long as they should, and that the trucks they ran with an auxiliary tranny were more reliable. They were set up with 4.10/5.87's or 4.30/6.33's
  10. cnsper
    cnsper Road Train Member
    Feb 28, 2014
    5,869
    Thanks Received:
    27,421
    Well when being stalked by a bear, my rear has 2 speeds,,,, Fast and Oh #####!
    Other than that I have not needed them.
