27 mhz ant with bnc connector
Discussion in 'CB Radio Forum' started by craig_sez, May 31, 2021.
  1. craig_sez
    craig_sez Road Train Member
    Sep 5, 2013
    5,570
    Thanks Received:
    2,714
    novascotia,Canada
    I have a sf 103 freq counter and it could use a better ant than factory..I have seen a few mentions of it so i figured i should look into it..
    Who makes a quality reasonablely priced one with a bnc connector..
    I seen a good # of chinese named ones and one called rubber duck but not seen anyone.mention if and who makes a decient one..
  2. Ridgeline
    22,613
    Thanks Received:
    120,190
  3. craig_sez
    Sep 5, 2013
    5,570
    Thanks Received:
    2,714
    novascotia,Canada
    The 1st and last would work ut they are cheaply priced,quality or crap?
    Being teliscopic an all doesnt that change the recieve like a normal cb ant type deal(swr,resonance ect)
    I just want something thats more geared to cb band
  4. Ridgeline
    22,613
    Thanks Received:
    120,190
    You don’t want receiving antenna, you will pick up more crap because the input circuit doesn’t have a means to attenuate the signal input by using tight signal tuning.
    I use the middle antenna because a counter is used up close to the radio unless I use a ring pickup on the so239.
  5. craig_sez
    Sep 5, 2013
    5,570
    Thanks Received:
    2,714
    novascotia,Canada
    Yeah the one that comes with it has to basically be on top of the antenna..I have seen a cpl vids where user was like 10ft away and still getting their radios signal..
    As of now i basically have to have my counter/signal strength meter sittin next to my ant to read anything...Thats why im looking for a better ant..
    Wish i could find the vid again...Surfed last night till my eyes were buggered up and i only got 3 hrs in the bunk instead of 7..
  6. craig_sez
    Sep 5, 2013
    5,570
    Thanks Received:
    2,714
    novascotia,Canada
    Oh and whats a ring pick up?
  7. Ridgeline
    22,613
    Thanks Received:
    120,190
  8. Ridgeline
    22,613
    Thanks Received:
    120,190
    You know I am thinking the counter’s front end isn’t as sensitive as it should be.
    you can get a long quality antenna from military surplus or make a simple wire antenna with a BNC connector.
  9. craig_sez
    Sep 5, 2013
    5,570
    Thanks Received:
    2,714
    novascotia,Canada
  10. craig_sez
    Sep 5, 2013
    5,570
    Thanks Received:
    2,714
    novascotia,Canada
    Im sure there is adjustment that can likely be done internally but i dont have the tools or know how to make such adjustment..
    For $70 its a cool tool but its $70 of so so quality too..
    Jjst another learni g tool to help me on this trip of understanding all this radio stuff.
    jdchet Thanks this.
