3406b air build up in fuel system
Discussion in 'Trucks [ Eighteen Wheelers ]' started by sbatson, Mar 27, 2012.
  1. sbatson
    sbatson Light Load Member
    Feb 14, 2008
    232
    Thanks Received:
    10
    Ft Worth, Texas
    We pulled the motor from another truck and it ran fine now its in another truck it will run for a few minutes untill it sucks the fuel out of filter runs ruff and dies. We have noticed that there is a lot of pressure when we took the filter off and we are getting no air anywhere either. What's wrong?
  2. JohnP3
    JohnP3 Road Train Member
    Feb 21, 2010
    1,594
    Thanks Received:
    683
    Rock Creek B.C. Canada
    The first thing you need to do is be sure the return line is clear, that is why you have preasure in the system.
    Then you need to find, where the air is sucking in, if the primary filter is filled then the engine ran and the level goes down, the air leak is before the filter. If you are using a 1212 check the drain is not open a bit.
    Just a thought!
  3. sbatson
    Feb 14, 2008
    232
    Thanks Received:
    10
    Ft Worth, Texas
    I dont know if it matters but the motor is a 3406b. I usally dont have to mess with this stuff but what is a 1212? And the motor came out of an 86 and now is in a 96. We changed everything over from the old motor except the exhaust mainfold and we put a cross over for the fuel tanks thats it. I didnt put the motor back in someone else did but theres a line coming off the main filter going down to a valve which there is a line coming off air pump that goes down to the same valve, does ths sound right?
  4. pichu
    pichu Light Load Member
    Jan 18, 2009
    103
    Thanks Received:
    19
    mexifornia
    :biggrin_25521:the 1212 is a fuel filter,cummins use but is good for cat too is depend what base you use !!!:biggrin_2555:
  5. marmonman
    marmonman Road Train Member
    Dec 14, 2009
    1,417
    Thanks Received:
    2,842
    central illinois
    I am no expert but I don't remember any lines from my air compressor hooking into my fuel system any where on my old B model cat.
    Can you post pictures ?
  6. Les2
    Les2 Road Train Member
    Jul 25, 2008
    5,150
    Thanks Received:
    2,288
    kicked back in my lazyboy...
    Mine either. Something isn't right!
    Might be bad fuel lines?
  7. sbatson
    Feb 14, 2008
    232
    Thanks Received:
    10
    Ft Worth, Texas
    Ill try and post pics tommorrow. But if you are looking at main filter to lines come off it one goes toward the back of the truck the other towards bottom/front of truck and there's a line that comes off air pump and goes to the same area as the fuel line. On the pump I have 2 lines that go back to tanks it looks like one coming off the side going to intake? 1 coming off bottom going to front cover and the big one going to the area of the fuel line. The filter is a off 2749.
  8. sbatson
    Feb 14, 2008
    232
    Thanks Received:
    10
    Ft Worth, Texas
    The black line from the pump is going down to this block which is at the bottom towards the front of motor and the small line is going to fuel filter. Ill post pics of the filter to. [​IMG]
  9. Les2
    Jul 25, 2008
    5,150
    Thanks Received:
    2,288
    That is your transfer pump and no air lines run into it. If you look closer your probably confusing lines or the air line is running past it.
  10. sbatson
    Feb 14, 2008
    232
    Thanks Received:
    10
    Ft Worth, Texas
