A concrete question, whats the tag axle called on a mixer truck?
Discussion in 'Experienced Truckers' Advice' started by All4Safety, Jan 8, 2019.
  1. All4Safety
    All4Safety Light Load Member
    Feb 6, 2018
    128
    Thanks Received:
    113
    What is the back tag axel on a redimix truck called? And is there a slang term? Thank you in advance! I see them all the time, I just wanna know.
  2. 201
    201 Road Train Member
    Apr 16, 2014
    12,621
    Thanks Received:
    25,905
    high plains colorado
    Nope, just a tag axle. for weight distribution.
    BillStep Thanks this.
  3. REO6205
    REO6205 Road Train Member
    Feb 15, 2014
    13,168
    Thanks Received:
    60,490
    California.
    I've heard them called "boosters". Also "tags".
    bottomdumpin Thanks this.
  4. x1Heavy
    x1Heavy Road Train Member
    Mar 5, 2016
    34,017
    Thanks Received:
    42,141
    White County, Arkansas
    It's just a tag axle. You are generally looking at the west coast mixers set up like that. Here in Arkansas our Mixers have a tag just forward of the drive tandems. Flip the air and down they go. Always pick em up when turning or on the job. It helps a little bit.
    Slang is used a little bit. If you heard get under the boot, that means back your mixer up the plant concrete output shaft boot a rubber device that will go into your rear loading chute into the drum.
  5. 25(2)+2
    Sep 18, 2006
    18,756
    Thanks Received:
    45,795
    the road less travelled
    Some call that one a stinger, because it appears to move like a bee using its stinger.
    There's a place along us 30 in Indiana that has about the largest collection and selection I've seen.
    The tractor trailer ones are especially different.
    slim shady Thanks this.
  6. Long FLD
    Long FLD Road Train Member
    Mar 4, 2015
    12,450
    Thanks Received:
    51,625
    I’ve heard then called bridge axles. I guess because they extend your bridge.
  7. snowwy
    snowwy Road Train Member
    Jul 6, 2009
    20,590
    Thanks Received:
    13,308
    I've heard swing arm and stinger.
    Around here they only get used if there's that much weight. Beyond the standard drops. A lot of times they won't be down.
  8. 25(2)+2
    Sep 18, 2006
    18,756
    Thanks Received:
    45,795
    Around here, those were added first to increase load carrying legally, most could haul 7 yds legally, but the mixer would hold 8 yrds, and enforcement was looking for writable things to go after.
  9. Rubber duck kw
    Dec 9, 2017
    6,092
    Thanks Received:
    17,686
    I wish they would enforce them a little better around our area, not for weight but just general "how big of a piece of #### are you driving today."
  10. Gumper
    Gumper Road Train Member
    Jan 7, 2018
    1,579
    Thanks Received:
    3,845
    Butte, MT
    Pusher axle is in front of the drives, tag axle is behind. Some people call them drop axles, others call them lift axles. Whatever.
    GreenPete359 Thanks this.
  11. mnmover
    mnmover Road Train Member
    Apr 5, 2009
    1,237
    Thanks Received:
    1,104
    Lichfield MN
    Sometimes they are called Loadmaster axles.
