A GPS with "via" option?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by STexan, Oct 20, 2011.
  1. STexan
    STexan Road Train Member
    Oct 3, 2011
    14,963
    Thanks Received:
    29,154
    Longview, TX
    I was wondering if there is a "Trucker" GPS that will build a route based on easily user inputted "via" option. i.e If I'm loaded in OKC and need to go to SLC ... the GPS will probably route through Kansas and over to Denver, Cheyenne, etc. But I want to go via Albuquerque and Cortez. Is there one that easily lets the user enter "via Albuquerque" and it build the route accordingly? This would also be used to set the route according to carrier's routing instruction that may differ from the GPS unit's prefferred route.
    Thanks
  2. cowboy_tech
    cowboy_tech Road Train Member
    Sep 27, 2008
    2,290
    Thanks Received:
    1,092
    Avondale, CO
    Copilot 9 for android let's you add a waypoint.
    You've been-----\/\/\/\-----Thunderstruck!!!
  3. Mark Kling
    Mark Kling Technology Contributor
    Sep 23, 2007
    10,935
    Thanks Received:
    4,216
    Statesville, NC
    The TND - you can either add it manually or drag and attach a point on the map.
    Thanks,
    Mark
