Abs module on 2018 cascadia location
Discussion in 'Questions From New Drivers' started by gentleroger, Mar 22, 2022.
  1. gentleroger
    gentleroger Road Train Member
    Jun 1, 2010
    7,452
    Thanks Received:
    20,268
    So my abs module just threw a bunch of codes and won't let the truck go into gear. I think it got wet or a connection bounced loose. Is the module anyplace accessible and can I just unplug it?
  2. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    Dec 15, 2021
    855
    Thanks Received:
    1,666
    Try shutting the truck off,turn the master off,let it set a few minutes and retry.Our 2019's do it sometimes.Most of the time it resets,sometimes it doesnt.Maybe unplug the trailer too,see if it resets.
    gentleroger Thanks this.
  3. gentleroger
    Jun 1, 2010
    7,452
    Thanks Received:
    20,268
    It's definitely a wiring issue. Had the same thing happen a month ago and I was hopping that something just bounced loose as I went through Indiana.
    It took me 4 youtube videos before I found the location and everything is plugged in, so I'm guessing when they made the repair they left a wire exposed or chaffing. Codes say 3 of the 4 wheel sensors and the brake pedal have low or bad voltage, plus two other things with "out of phase signals".
    Tow truck will be here shortly, but I was hopping to at least get out of the driveway.
  4. North Pole Nightmare
    Dec 15, 2021
    855
    Thanks Received:
    1,666
    Road salt got my starter last month,380,000 miles on the truck.Mechanic came out,tapped on the starter with a hammer while I held the key in start and if fired up .I didn't shut it off until I got back to our shop in Texas.
