AC not working giod
Discussion in 'Ask An Owner Operator' started by gerardo1961, Apr 24, 2022.
  1. gerardo1961
    gerardo1961 Road Train Member
    Feb 21, 2010
    1,746
    Thanks Received:
    613
    Miami
    Truck freightliner Colombia.2007
    Ac not cooling good.coilant Lines Frozen with ice.how i can fix this
  2. Siinman
    Siinman Road Train Member
    Mar 5, 2017
    5,309
    Thanks Received:
    13,482
    Kansas City, MO.
    Go to AC repair person for fix.
    DUNE-T Thanks this.
  3. Big Road Skateboard
    May 2, 2021
    6,236
    Thanks Received:
    34,372
    Probably add freon
  4. Dino soar
    Dino soar Road Train Member
    Dec 8, 2017
    4,791
    Thanks Received:
    26,878
  5. ProfessionalNoticer
    Apr 25, 2021
    2,941
    Thanks Received:
    7,858
    Have it recharged and leak tested.
    InTooDeep Thanks this.
  6. kemosabi49
    Jan 13, 2013
    10,684
    Thanks Received:
    45,852
    SW Arkansas
    ^^^^ What he said. It is a closed system so if you are low on freon, you probably have a leak. You need to have the system checked. And check your cabin filters. Plugged up cabin filters will not allow air flow through and can result in the system freezing up.
    InTooDeep and ProfessionalNoticer Thank this.
  7. gerardo1961
    Feb 21, 2010
    1,746
    Thanks Received:
    613
    Miami
    A C is Working,looks like was only in the hills the problem
