Accident showing with swift during training. Can I fight it?
Discussion in 'Questions From New Drivers' started by bluestreet, Mar 26, 2017.
  1. bluestreet
    bluestreet Bobtail Member
    Mar 26, 2017
    10
    Thanks Received:
    So I was going to a warehouse in the busy city of Atlanta delivering to a Kroger (reefer) and there was a really tight entry to where it was a 90 degree angle. The previous day, my mentor went through the same entry and said "this is a really tight corner so I have to be careful". He got through after going slow.
    A day later, I drove through it at night and went slow, but ended up cracking the front passenger bumper on a guard rail. The crack is only a few inches. I had to call swift and report it. I thought it was an incident, but apparently, it is listed as an accident. The mentor was up with me and was guiding me, I just wasn't able to get through it.
    My problem is, I'm not sure that entrance is the way I was supposed to go through because after you back into the dock and get the trailer unloaded, he nor I ever drive back the way we came from as there is another entry that is much easier to get in and out of.
    There is a guardrail where I got the accident for a reason. Maybe because they don't want trucks going that way. It's extremely tight, but the mentor said it was ok to go that way as he went that way previously.
    It's been a few months since the accident and I am now solo, but it is what is keeping me from platinum status, but now I'm wondering if I can fight it or is it too late? I thought it was an incident, since no police were involved, but that isn't the case. Photos of the guardrail were taken at the time and sent in to safety and the location is still on file, so they will be able to see that there were two entrances. The mentor just told me to go into the 90 degree one.
  2. Chinatown
    Chinatown Road Train Member
    Aug 28, 2011
    75,004
    Thanks Received:
    171,005
    Henderson, NV & Orient
    Time to change companies; you're obviously not a valued employee.
    Set up an orientation date with a new company then quit and get on with your life.
    There's some really good companies that laugh at situations like this because they see good drivers getting thrown under the bus for simple things; now they can hire that driver and treat him right and put him in nice truck with all the driver amenities such a APU, refrigerator, etc.
  3. CSDixon
    CSDixon Light Load Member
    Feb 7, 2017
    208
    Thanks Received:
    242
    Denver CO
  4. boneebone
    boneebone Road Train Member
    Mar 13, 2009
    2,296
    Thanks Received:
    2,367
    Whether it was the right or wrong entrance, the point is you hit a stationary object, which is considered a Preventable Accident.
    Even though it's not reported on your DMV record, it is still a Accident that could've been prevented, by you. It doesn't matter if your Mentor was guiding you, you're the one driving. If you weren't sure about the clearance, you should've got out of the truck and looked.
    It'll fall off from their records in a couple years and chalk it up to being a Newbie and move forward.
    Case Closed
    Thull, crb, SESteve83 and 5 others Thank this.
  5. Chinatown
    Aug 28, 2011
    75,004
    Thanks Received:
    171,005
    DAC report is used as a form of slavery. Companies hit the DAC with minor stuff trying to force the driver to stick around.
  6. bluestreet
    Mar 26, 2017
    10
    Thanks Received:
    do accidents really fall off after a couple of years???
  7. tinytim
    tinytim Road Train Member
    Oct 29, 2007
    5,143
    Thanks Received:
    18,311
    Northern Ontario
    Ryan423 Thanks this.
  8. Lepton1
    Lepton1 Road Train Member
    Nov 23, 2012
    12,647
    Thanks Received:
    25,588
    Yukon, OK
    IIRC to achieve Platinum status you can have one preventable in the last 12 months, average at least 2100 miles per week, and be on time 99.5% of the time. You can look up the qualifying factors at any kiosk and see how you stack up. If you have any questions talk to your DM. The preventable should drop off after a year.
    Getting to Platinum will open up Mac 30, giving you the ability to select from up to three loads. The quarterly bonus is $0.04 per mile.
    Regarding trying to dispute the preventable, I doubt that you will be able to remove it. You were at the wheel when you hit something. Although you only put a small crack in the bumper/fender, that crack WILL get bigger because of shakes and vibrations on the road and require considerable expense to repair.
    You learned a valuable lesson about planning and the need to GOAL even when moving forward. You also learned that Google Satellite View is invaluable for trip planning.
    crb, Ryan423 and A21CAV Thank this.
  9. pattyj
    pattyj Road Train Member
    Jul 19, 2008
    22,474
    Thanks Received:
    20,137
    Sioux City,ia
    From what I gather with your post it could have been much worse.But the point is you were in full control of the truck.Learn from it and dont come up with excuses why it happened.
    mpm, Toomanybikes, tinytim and 3 others Thank this.
  10. bluestreet
    Mar 26, 2017
    10
    Thanks Received:
    ok, but do these things fall off of your dac report in a couple of years as another poster stated?
