After delivery, who is responsible for cleaning the tanker out?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by camaro68, Jan 29, 2014.
  1. camaro68
    camaro68 Medium Load Member
    Dec 17, 2011
    627
    Thanks Received:
    290
    Tennessee
    When you make your delivery, who is responsible for cleaning the tanker? When it's a hazardous load, I'm thinking the company receiving the load would clean the tank out. How does that work?
  2. rubberducky68
    rubberducky68 Road Train Member
    Sep 9, 2010
    2,059
    Thanks Received:
    811
    Jefferson GA
    Tank wash companies. You will take the tank to whatever tank wash your company tells you to once you deliver. Drop it and write it up for cleaning. Some companies may have you sit and wait on it to be cleaned so you can take it and get re-loaded. I can't tell you much about that part because Superior has us just drop them and grab a clean and go on. Once in a blue moon we might have to wait on one to get cleaned but in my experience I don't do that.
    HauntedSchizo19 and camaro68 Thank this.
  3. HauntedSchizo19
    HauntedSchizo19 Medium Load Member
    Dec 19, 2013
    481
    Thanks Received:
    148
    Southern Tier, New York
    What rubberducky68 said. I read somewhere, too, that obtaining the tank wash card (basically, something indicating that the tank has been in fact washed) is something to do as well. Some shipper's want to see it, some don't care. That's something I read along on one of these threads on here.
    Best of luck to you!
    camaro68 Thanks this.
  4. Big Duker
    Big Duker "Don Cheto"
    Sep 18, 2007
    2,921
    Thanks Received:
    2,867
    Weatherford, TX
    That's correct. Just a receipt. No different then weight ticket. Just to make sure someone did clean the thing before they brought it to load. Doesn't have to be hazardous at all. Just some of what is shipped has to be completely clean. Hate to get to receiver and have them do test and reject it because a gallon or two of something tainted load. When we haul diesel we can't load an ethanol load until we have run one of gasoline or tank is cleaned which isn't going to happen. It has happened and nothing ever came of it. But once company found out everyone was reminded and culprit{always OO} was removed from hauling ethanol for a while or for good.
  5. slim shady
    slim shady Road Train Member
    Sep 14, 2011
    3,468
    Thanks Received:
    14,689
    Chicago, Il.
    What has already been stated, and you'll need to leave a copy of last contained in the manifest box on your tanker, a lot of what I want do is dedicated tankers, so its load out and come back empty and reload same product
    Sent from my RM-845_nam_vzw_100 using Board Express
  6. Flatbedder73
    Flatbedder73 Medium Load Member
    Dec 30, 2012
    464
    Thanks Received:
    354
    Langhorne, PA
    Our OTR drivers are assigned their tractor AND trailer...spend more time at the tank wash than at shippers or receivers!
  7. camaro68
    Dec 17, 2011
    627
    Thanks Received:
    290
    Tennessee
    How long does it normally take to clean one? Do they clean tankers using steam?
  8. korky
    korky Light Load Member
    Aug 14, 2013
    97
    Thanks Received:
    56
    AZ
    Depends on what product was in the trailer.
    I hauled chemicals, so it would take about an hour if you got right in. Whether you used hot water, detergents or just a cold water flush, it was all the same.
    If you are hauling food grade, it usually takes longer. How long depends on what product you had in the trailer. I have waited behind a food grade trailer for 2+ hours. Don't exactly know what food grade cleaning entails since I never hauled it.
    It also depends on the tank wash and the equipment they have. Danny's here in Avondale, AZ takes about an hour. Rainbow tank wash in Carson, CA took about 10 to 15 mins. because they have a really high pressure set up.
  9. slim shady
    Sep 14, 2011
    3,468
    Thanks Received:
    14,689
    Chicago, Il.
    Its not only getting your tank washed, You'll have what ever hoses you used and your pump will also need cleaning
  10. korky
    Aug 14, 2013
    97
    Thanks Received:
    56
    AZ
    Sorry, I should have mentioned that. The two places I listed always ask but other washouts might not so you have to be on the ball.
    Even with the hoses and pump washout, the times are the same since they wash those items out at the same time as your tank is getting washed.
    After the washout is complete, I always go up top and look inside the trailer with my handy dandy flashlight to make sure there isn't any residue or funky smells. After that, make sure everything is locked up tight, get your receipt and go get loaded.
    I always ask for a second copy of the receipt. One for the manifest box and one for my records in case the one in the box mysteriously disappears. Most places will ask for it before they load you.
