Am I correct about the thanks signal?
Discussion in 'Questions From New Drivers' started by Wesker, Aug 27, 2011.
  1. Wesker
    Wesker Bobtail Member
    Jul 14, 2011
    20
    Thanks Received:
    6
    I know whenever you pass a truck and get in front of it, it is polite to have a flash on the back of the truck to show thanks, especially when the driver on the back flashes his hi beam to indicate you can pass. At first I thought the thanks signal of the quick flashes was a 4 way flasher signal but I've seen it and it is a quick flash that does not look like the four way flasher and at the end I found out it was the hi beam light because I see a truck try to pass another truck and the truck behind him was having that quick flashes on the back so I figured the guy behind him must have turn that hi beam on and off to indicate the guy in front of him can pass, so that quick flashes on the back came from the hi beam light, am I correct? and at first when I try to say thanks after the guy behind me flashes his hi beam so I can pass, I turn on the 4 way flasher and I feel stupid after I learned that it was the hi beam.
  2. zebcohobo
    zebcohobo Vincent Van Gopher
    Jul 19, 2010
    1,479
    Thanks Received:
    1,223
    Redbank,SC
    Flashing the highbeams is annoying. The guy that has passed and gotten over has hit the interrupt switch not the 4ways. Please don't flash your highbeams at me. It temporarily blinds me. I'd much rather get a quick on/off of the headlights or nothing at all. This is one instance when the cb is especially handy but due to all the bs on 19 most drivers don't have them on.
    dirtyjerz and Wiseguywireless Thank this.
  3. Diesel Dave
    Jan 20, 2010
    8,833
    Thanks Received:
    25,904
    Hesperia, Ca.
    The way it's suppose to be done is as follow's, 1). When you clear the truck your passing, they are "SUPPOSE" to turn off there headlight's to let you know, BUT the "NEW GENERATION OF STEERING WHEEL HOLDER"S", use the the HIGH BEAM FLASH which blind's you. 2). After you have been giving the clear signal(come back over), your "SUPPOSE" to flash your "TAIL LIGHT'S/MARKER'S on the trailer (not use your 4 way's).
    dirtyrabbit and nuts&bolts123 Thank this.
  4. Diesel Dave
    Jan 20, 2010
    8,833
    Thanks Received:
    25,904
    Hesperia, Ca.
    "DITTO"........... Thank you
    zebcohobo and Everett Thank this.
  5. rockee
    rockee Road Train Member
    Apr 17, 2007
    1,393
    Thanks Received:
    673
    Pacific Northwest
    I will use my 4 ways during the day and interrupt switch at night.
    otherhalftw and Raiderfanatic Thank this.
  6. Diesel Dave
    Jan 20, 2010
    8,833
    Thanks Received:
    25,904
    Hesperia, Ca.
    I "NEVER" use my 4 way's !!!!!!!!!!!
    zebcohobo Thanks this.
  7. Stoney
    Stoney Medium Load Member
    Mar 15, 2011
    329
    Thanks Received:
    1,304
    Az
    Why not?
    - Conservative to the Bone.
  8. Diesel Dave
    Jan 20, 2010
    8,833
    Thanks Received:
    25,904
    Hesperia, Ca.
    I never use my 4 way's as courtesy gesture when I come back over to the truck lane. Like I said earlier, the steering wheel holder's do it. "I DON"T" !!!
  9. Stoney
    Mar 15, 2011
    329
    Thanks Received:
    1,304
    Az
    Ok Mr Big Rig Trucker!
    Lonesome, Tazz and Injun Thank this.
  10. Diesel Dave
    Jan 20, 2010
    8,833
    Thanks Received:
    25,904
    Hesperia, Ca.
    I was checking your profile and NOTICE you made a good friend already, What did he call you again?..........:biggrin_2559:....... I believe from your comment, I know your kind..........
    roehl929 Thanks this.
