Hey guys....I have had a CDL Since mid 90's but have never driven...I am a weigh scale tech and we have a old test truck...84 white....I know bad...LOL ok I have only been driving it for a few months ...the other tech who drove it left... he complained on several things wrong with the truck.....I took over and found the same things wrong....marker lights bad brakes...ect...well I noticed the DOT inspection was out on the truck....so we took it into the local shop.... they sent us the list...as reads...DOT inspection did not pass.... needs brakes, needs drums all around..2 marker lights out...steering shaft needs to be replaced due to slack, tie rod ends bad due to slack, one u-joint bad, and wheel seal bad on RT rear drive, customer denied repairs.... Now here is the question.....I am not up on all the DOT fines and such... The Boss wants me to drive the truck around town and check scales....I am planning to tell him NO....in the morning until the truck is Fixed....
You have every right to stand up and say the truck is unsafe and here's why. You're even backed by the FMCSA. However, just remember that TN is a "Employment At Will" state and unless you have a contract they can fire you on the spot and don't need a reason. So if I were you I'd would go about the situation very diplomatically. You always want to protect your CDL and never drive a truck that's in that type of condition. Maybe you should give the boss the list and suggest to start with the major safety items first.
Don't drive it, you are looking at several possible OOS issues with that truck. Very serious and will stack up your CSA score very fast.
So perhaps you are finding out just WHY the other tech left. You need to ask yourself, "is this job worth my life, or the life of someone else?" As was said, be diplomatic about it, if that is possible. But no way should you drive this vehicle until it is in drivable condition.
I think a good guide would be would you put your loved ones on the same road as the truck? If you can't honestly say yes to that then you shouldn't operate it as someone else's loved ones are going to be on that same road your operating it.
I wouldn't drive it. Here is the worst part of the situation. You know there are problems with the equipment. It was taken to a shop where the problems were documented and repairs were refused. Now if you were an attorney following an accident where this vehicle was unable to stop, wouldn't you be excited? If someone is injured or killed, someone will go to prison. It is not worth it.
