any idea what part this is
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 4noReason, Dec 26, 2020.
  1. 4noReason
    4noReason Road Train Member
    Nov 29, 2012
    2,377
    Thanks Received:
    731
    got a glider columbia. so hose part list wont come. up. hose below bigger hose any idea what it is
  2. McMahons Trucking
    McMahons Trucking Light Load Member
    Jul 4, 2018
    274
    Thanks Received:
    119
    Looks like a coolant hose. Where does it connect?
  3. 4noReason
    Nov 29, 2012
    2,377
    Thanks Received:
    731
    the head to a pipe . its a tiny one. looks like elbow hose.
  4. McMahons Trucking
    Jul 4, 2018
    274
    Thanks Received:
    119
    Must be a bypass of some sort.
  5. Brandt
    Brandt Road Train Member
    Sep 17, 2012
    4,515
    Thanks Received:
    6,184
    That's the blow by vent hose on a S60 Detroit. It should lead down to bottom of engine.. Engine oil some smoke will come out at bottom of the hose.
    Rideandrepair and Hulld Thank this.
  6. 4noReason
    Nov 29, 2012
    2,377
    Thanks Received:
    731
    do u mean the bent one below the upper radiator hoswme?
  7. Brandt
    Sep 17, 2012
    4,515
    Thanks Received:
    6,184
    Yes, the one below the BIG coolant hose. that has bent rubber hose hooked to metal tube. I'm believe that what it is. It should go down side of engine and it blow oil and smoke out the bottom and onto the ground. When the engine get more miles it will blow more smoke and more oil will drip out of it.
    4noReason, Rideandrepair and Hulld Thank this.
  8. Brandt
    Sep 17, 2012
    4,515
    Thanks Received:
    6,184
    The blow bye vent hose is so the crankcase does not build up pressure. The new emissions don't let this happen anymore.
    4noReason and Rideandrepair Thank this.
  9. Rideandrepair
    Aug 8, 2015
    17,344
    Thanks Received:
    56,270
    No need to change it, doesn’t hold pressure or any fluid.
    4noReason Thanks this.
  10. 4noReason
    Nov 29, 2012
    2,377
    Thanks Received:
    731
    yup u 100% right. wat a relief. finding that tiny hose is so hard
    Brandt Thanks this.
