Any one ran both ISX & C-15 ?
Discussion in 'Ask An Owner Operator' started by 2hellandback, Jan 14, 2008.
  1. 2hellandback
    2hellandback Heavy Load Member
    Dec 19, 2007
    978
    Thanks Received:
    237
    Blackfoot Idaho
    What is your opinion on these 2 engines for reliabilty and fuel economy ?
    ISX 475 hp T-600 yr 2003 13 speed 3:58s
    C-15 500 hp w900L yr 2000 15 speed 3:70s
  2. MedicineMan
    MedicineMan Road Train Member
    Jan 13, 2007
    5,799
    Thanks Received:
    6,440
    Woodville, TX
    I'v never driven an isx but I don't need to in order to answer that question. you are looking at a smaller cummins in a MUCH more aerodynamic truck with a lower rear gear. It would be much better on fuel than the cat but I'v heard lots of problems on the ISX so you may want to look into that. I don't pay too much attention to them since I'm not in the market for anything that new.
  3. TORQUE WRENCH
    TORQUE WRENCH Bobtail Member
    Jan 10, 2008
    24
    Thanks Received:
    4
    CHANDLER,AZ.
    Maybe I can help.........We run both of these engines in our fleet. But I have one question you said the T600 is a 2003, does this cummins isx have an EGR? Also where do you plan on running this truck, city or highway?
  4. 2hellandback
    Dec 19, 2007
    978
    Thanks Received:
    237
    Blackfoot Idaho
    Not sure if it has an egr or not ill have to ask.Both trucks will be used in light oilfield support or road contruction pulling a single belly dump hauling gravel asphalt roto mill chips etc.
  5. TORQUE WRENCH
    Jan 10, 2008
    24
    Thanks Received:
    4
    CHANDLER,AZ.
    Hey 2hellandback, keep in mind that the aerodynamics of the T600 may not be much help on saving fuel at lower speeds......40, 45 mph.At 50 mph and above aerodynamics start paying off...... The C15 CAT and the CUMMINS ISX are both 15 liter engines and in most cases the HP rating can be turned up through the ECM. But getting back to your question which engine gets better fuel mpg.......In our fleet the CUMMINS ISX with out EGR seems to have the edge in better fuel milage than our C15 CATS.........on the other hand our CUMMINS ISX with EGR have there own set of problems....BE SAFE!!!!!!
  6. 2hellandback
    Dec 19, 2007
    978
    Thanks Received:
    237
    Blackfoot Idaho
    TORQUE WRENCH so what engine did you like the most then?
  7. MedicineMan
    Jan 13, 2007
    5,799
    Thanks Received:
    6,440
    Woodville, TX
    ya I believe it's the egr's I've heard about. Basicly he is saying if the cummins has an egr then go for the cat, if it doesn't have an egr then go for the cummins
  8. TORQUE WRENCH
    Jan 10, 2008
    24
    Thanks Received:
    4
    CHANDLER,AZ.
    This is what I am saying..........
  9. 2hellandback
    Dec 19, 2007
    978
    Thanks Received:
    237
    Blackfoot Idaho
    OK what has been the reported problems with the EGRs
  10. MedicineMan
    Jan 13, 2007
    5,799
    Thanks Received:
    6,440
    Woodville, TX
    needing frequent replacement, rough running and poor fuel economy.
