apu not blowing cold
Discussion in 'Questions From New Drivers' started by krazzyboi_44, Aug 23, 2014.
  1. krazzyboi_44
    krazzyboi_44 Light Load Member
    Apr 30, 2008
    297
    Thanks Received:
    42
    BAton Rouge,Louisiana
    My apu is starting to be a pain in the #####. As soon as I turn it on and it start to blow cold it goes off and I get an error code saying engine running failure. And when I use the manual start button it just blows warm air.
  2. Snailexpress
    Apr 28, 2014
    2,675
    Thanks Received:
    6,068
    Rocky
    Move truck in Wyoming. Ouch... Is your heater working???
  3. Rugerfan
    Rugerfan Road Train Member
    May 3, 2011
    7,327
    Thanks Received:
    36,155
    Redding,CA
    I had that happen to me a few months ago and it was because of the hose that leads out to the main vent under the floor had worn a hole in itself by rubbing against other things in the bunk.. is it a peterbilt?
  4. crxdc
    crxdc Road Train Member
    Jun 24, 2013
    1,739
    Thanks Received:
    1,202
    Las vegas NV
    Did you check the oil and water? that can cause the fault then it will only turn on for a second then shut off. heck fluids then hit reset on th box under bed
  5. Ridgeline
    22,367
    Thanks Received:
    116,012
    Take it to a shop that works on that brand APU. These things are simple but made complex so only those who are supposed to service them are servicing them.
  6. ironpony
    ironpony Road Train Member
    Sep 23, 2007
    17,502
    Thanks Received:
    12,015
    Ask my GPS...
    Krazzyboi... you're a Prime driver, posting these questions in the Prime forum will get you more specific answers than you'll get in the generic new guys forum.
    First, send a macro 21 to to road assist describing the problem. They'll get back to you, but only respond to them using macro 21... they don't see anything when you respond with the generic REPLY function. That only goes to dispatch.
    If they can't get it working with you on the road, you need to let your FM know about it, and get routed to the nearest company shop. While you're enroute it should be OK to idle the truck for a/c, but that's only short term.
    lovesthedrive Thanks this.
  7. n3ss
    n3ss Heavy Load Member
    Nov 4, 2013
    737
    Thanks Received:
    340
    If it's a rig master, does it sound "weak" (sputter, RPMs fluctuate/drop, or something) when the AC kicks in? And then after a few seconds of air the APU cuts off and you get that error?
    That's what mine does. Check the air filter on the APU.
    I haven't yet figured out what causes the air filters to get so nasty so quick, as I haven't been able to set an appointment to have the thing looked at. It took all of 6 weeks on a brand new filter for it to start acting up again.
  8. Scoots
    Scoots Light Load Member
    Sep 29, 2013
    120
    Thanks Received:
    322
    Chicago, IL
    So hypothetically, let's say I see a Prime truck in the right lane doing its usual 30-50 m.p.h. under the posted speed limit, there is road construction ahead in the left lane and I have a delivery I have to make sometime this decade (I assume Prime deliveries don't have such rigid time constraints)... What macro do I have to punch in to direct said Prime truck to the nearest bicycle path where its not obstructing traffic?
  9. ironpony
    Sep 23, 2007
    17,502
    Thanks Received:
    12,015
    Ask my GPS...
    Wrong thread rookie.
  10. Palazon
    Palazon Road Train Member
    Feb 5, 2009
    1,430
    Thanks Received:
    912
    Tacoma, WA
    Agreed, but I have to admit that I chuckled....
