apu with perkins engine
Discussion in 'Questions From New Drivers' started by cata917, Oct 24, 2011.
  1. cata917
    cata917 Bobtail Member
    Jun 24, 2011
    32
    Thanks Received:
    Brooklyn, NY
    i do have a freightliner coronado truck with an apu on it , but the perkins engine won't start , is cranking , one mechanic from pape machinery , in california checked and he said is the solenoid is bad , he said is got in a short circuit , or something like that, the apu is made by idle solution by temco, and the are out of business now, anybody have this apu please help! thank you !
  2. seabring
    seabring Road Train Member
    Apr 24, 2011
    1,844
    Thanks Received:
    1,882
    Get onto Perkins, they should be able to help.
  3. farmerleach
    farmerleach Light Load Member
    Dec 1, 2009
    80
    Thanks Received:
    28
    Cat bought perkins a few years ago. So you may be able to get some help from a cat dealer.
  4. Bent Wrench
    Bent Wrench Medium Load Member
    Aug 11, 2009
    588
    Thanks Received:
    205
    Cornholio, OR
    back where he started "Pape" :^)
    Perkins didn't make starters though.
    If jumping the solenoid does not make it crank any good electric shop should be able to fix it.
  5. Passin Thru
    Passin Thru Road Train Member
    Mar 8, 2007
    1,918
    Thanks Received:
    565
    VA
    Take it ot any Thermoking dealer as Thermoking has Perkins engines. The solenoid hes talking about is the fuel cutoff solenoid.
