Beeping sound when starting/running International Terrastar w/Maxforce
Discussion in 'Questions From New Drivers' started by cajundrag, Feb 15, 2018.
  1. cajundrag
    cajundrag Bobtail Member
    Feb 15, 2018
    7
    Thanks Received:
    Stupid question, when starting my truck a continuous beeper sounds occurs, no warning lights are displayd> any ideas?
  2. Steel Dragon
    Steel Dragon Road Train Member
    Nov 23, 2015
    2,681
    Thanks Received:
    2,833
    Door not closed.
  3. Oldironfan
    Oldironfan Road Train Member
    May 22, 2017
    5,777
    Thanks Received:
    5,543
    Maybe it's because your air pressure is building up.
    Smut Thanks this.
  4. RumbleTruckin
    RumbleTruckin Light Load Member
    Jan 14, 2018
    118
    Thanks Received:
    94
    most likely it is air pressure and it stops when it gets over 60 psi
    Steel Dragon Thanks this.
  5. Oldironfan
    May 22, 2017
    5,777
    Thanks Received:
    5,543
    Did you check you blinker fluid? You might want to.
    And your sand rail injector may need cleaning.
  6. TankerYankerD001
    TankerYankerD001 Light Load Member
    Dec 19, 2017
    68
    Thanks Received:
    40
    Baltimore MD
    Is it beeping before you start or while you starting
  7. Justrucking2
    Justrucking2 Road Train Member
    Sep 12, 2017
    3,211
    Thanks Received:
    4,293
    Plymouth MI
    Is it beepbeepbeep or beep beep beep? Very important.
    Smut, Bakerman and Steel Dragon Thank this.
  8. Enzo_Guy
    Enzo_Guy Light Load Member
    Feb 15, 2018
    56
    Thanks Received:
    83
    Laredo, TX
    If it's a long continuous beep it's likely low air pressure.
  9. bigkev1115
    bigkev1115 Road Train Member
    Oct 23, 2009
    2,364
    Thanks Received:
    3,618
    Alexandria, AL
    I know some internationals when you turn them off and crank them up, they sound like someone hitting a Kia or Hyundai horn about a 100 times
  10. cajundrag
    Feb 15, 2018
    7
    Thanks Received:
    1. Beep Beep Beep
    2. Why didn't I think of that !!!!!
    Justrucking2 Thanks this.
