Best non epa truck engine to try and make 600hp
Discussion in 'Experienced Truckers' Advice' started by 1970Kenworth, Dec 1, 2018.
  1. 1970Kenworth
    1970Kenworth Bobtail Member
    Nov 30, 2018
    17
    Thanks Received:
    Pre epa truck engine which one would you buy for a dump truck For short hills hauls in the mountains?
    Looking to be able to hop it up a little to lot
  2. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    Oct 22, 2016
    2,439
    Thanks Received:
    6,798
    North Dakota, Eh?
    7CZ C16 if you can find one.
    Lepton1 Thanks this.
  3. stillwurkin
    stillwurkin Road Train Member
    Dec 2, 2017
    1,756
    Thanks Received:
    2,856
    Any 3406 up to c-15 to 16. Set right also old k series cummins. Old v- 8 macks, guys had fun with. Let your wallet be your guide. Common sense with your right foot, as heat and fire in the 6 holes will have severe consequences .
    Crude Truckin' Thanks this.
  4. 1970Kenworth
    Nov 30, 2018
    17
    Thanks Received:
    Ok why the 7CZ c16
    I’ve been looking around I like the c16 .
    This is a slow build so I have plenty of time Unless my old leaky small cam Cummins breaks
  5. x1Heavy
    x1Heavy Road Train Member
    Mar 5, 2016
    34,016
    Thanks Received:
    42,139
    White County, Arkansas
    Only 600? Why not try for 1000+ You might be able to shove one of the nice 1000's out merry old england into a 20 foot box delivered to your shop. At least the old ones over there know how to get horses.
    alds and wore out Thank this.
  6. gokiddogo
    gokiddogo Road Train Member
    Mar 5, 2012
    8,786
    Thanks Received:
    14,769
    Ontario Canada
    1500 or stay home
  7. cdgoza
    cdgoza Light Load Member
    Jan 24, 2015
    212
    Thanks Received:
    128
    Saw a glider Pete with a C-18 awhile back. That’d probably be able to handle it.
    Lepton1 and Nothereoften Thank this.
  8. AModelCat
    29,390
    Thanks Received:
    161,302
    Lot of folks tell me the pre-EGR 14L Series 60 is a solid platform for pushing big power.
  9. Zeviander
    Zeviander Road Train Member
    Jan 23, 2015
    4,886
    Thanks Received:
    36,995
    Winnipeg, MB, CA
    What are you going to be running for gross weights? 600hp trucks are kind of a waste on anything less than 140,000+
    Any "King of the Hill" CAT comes from the factory at 625hp/2050lbft. They aren't cheap though.
    Nothereoften Thanks this.
  10. Long FLD
    Long FLD Road Train Member
    Mar 4, 2015
    12,452
    Thanks Received:
    51,640
    Are you talking at the flywheel or at the wheels? Just look for an old E model 600 or a C16. If you’re a Cummins fan there’s always the Signature 600 too.
    stillwurkin, Nothereoften and jsnell Thank this.
  11. Sumtinlidat
    Sumtinlidat Light Load Member
    Dec 17, 2017
    134
    Thanks Received:
    390
    Las Vegas Nevada
    If we’re just talking about building a motor from scratch. Budget will be your guide. You can start with any cat 3406 whether it be a E series motor. Or mechanical B series motor. They can all be built to produce/handle 600. 600 is like the first step into “big” motors being you can order a new production motor from factory spec at 600. Cat motors being your easiest to build with many factory and aftermarket parts readily available. If you got the money and have a reputable builder, a Detroit V12 or Cummins KT series motor would be an awesome power plant.
    I personally drive a 93 Pete exhd with a mechanical cat with that was built with parts rated for 525hp. Pump wide open. I’d say she’s not the full 600. But she’ll keep up with the best. We have trucks in our fleet that are E series motors and ISX’s that are Pittsburgh powered that are in the 700+ club. But make sure if you spending all that money one a motor build, that you upgrade your driveline and transmission as well. I’ve seen many people skimp out on there driveline and spin universals and tear clutches apart.
    Lepton1, Nothereoften and Long FLD Thank this.
