Best way to run a wire from battery in 21 T680
Discussion in 'CB Radio Forum' started by Thomasmcdaniel9, Mar 2, 2023.
  1. Thomasmcdaniel9
    Thomasmcdaniel9 Bobtail Member
    Jan 30, 2019
    4
    Thanks Received:
    Need help on finding the best route to fish a wire to my battery up to the CB compartment
  2. RubyEagle
    RubyEagle Medium Load Member
    Apr 17, 2010
    632
    Thanks Received:
    790
    Drill a hole under your entry floor trim plate. Run it up behind the plastic up the pillar.
    Thomasmcdaniel9 Thanks this.
  3. craig_sez
    craig_sez Road Train Member
    Sep 5, 2013
    5,570
    Thanks Received:
    2,714
    novascotia,Canada
    I would look around for factory cable holes n such before i would drill..
  4. Side pipes
    Side pipes Light Load Member
    Nov 27, 2022
    93
    Thanks Received:
    72
    Ireland
    And keep a check on the wires once connected to the battery terminals road salt will eat wiring
  5. Neverready
    Neverready Medium Load Member
    Jul 24, 2014
    406
    Thanks Received:
    330
    Pocomoke City, Md.
    On the 23 t680 there are unused ports plugged with rubber stoppers on the lower firewall. If 21 has those you can use one of those to run power into cab then fish it thru the side pillar.
