Brake issue on my stepdeck - 2010 Manac 53 ft slider spread
Discussion in 'Flatbed Trucking Forum' started by Mommas_money_maker, Nov 11, 2012.
  1. Mommas_money_maker
    Mommas_money_maker Road Train Member
    Oct 2, 2011
    1,122
    Thanks Received:
    765
    North Carolina
    Having an issue with the driver side rear axle brake on my stepdeck and wondering if you guys have got any advice on what to fix. I just replaced the shoes on the trailer and one drum about 6000 miles ago. I am having issues with the brakes where I replaced the drum specifically locking up when the others arent (anti lock brakes 2010 model year). It has also had the axle seals replaced on this axle (both sides) and new hardware kits were installed with the shoes. The brake is adjusted right but when I apply the brakes, this one wants to lock up and just had (only this brake) give me some smoke when I was coming down Ashland pass on I-5 heading home so its obviously applying itself harder than the other brakes. Got any ideas?
  2. WMGUY
    WMGUY Road Train Member
    Jan 1, 2011
    1,684
    Thanks Received:
    800
    Nine Mile Falls, WA
    what about the poportioning valve, could be sending too much pressure to that brake, or could be a bad air can
    SHC and Mommas_money_maker Thank this.
  3. Mommas_money_maker
    Oct 2, 2011
    1,122
    Thanks Received:
    765
    North Carolina
    I was thinking that it could be the valve but wanted some good second opinions before I go tearing into it. I dont think its the can but of course I could be wrong.:biggrin_255:
  4. bender
    bender Road Train Member
    Jul 20, 2010
    2,105
    Thanks Received:
    1,360
    Don't Kid Yourself
    It's most likely the new drum on that one wheel position giving you better braking on just that wheel.
  5. allan5oh
    allan5oh Road Train Member
    Jan 6, 2010
    1,557
    Thanks Received:
    556
    Winnipeg, mb
    Very unlikely its an air system problem. Two things to check for. The first is the s-cam and bushings. With the brakes released attempt to pry the slack adjuster up and down as well as sideways. Very little play is acceptable. The bushing right beside the slack always wears before the brake side bushing does. This will cause exactly what you describe. The aecond is an out of round drum. We are seeing a lot of Chinese knockoff drums. With a full load make a light hand valve application at low speed. If there is surging you may have an out of round drum. You could also look at the drum to see if you have any spots where the shoe is not making contact.
  6. Mommas_money_maker
    Oct 2, 2011
    1,122
    Thanks Received:
    765
    North Carolina
    I was wondering about the slack adjuster . Right before I replaced the brakes and this drum I had noticed a little of the issue back there but decided since the shoes were worn out that it had something to do with it. The reason I replaced this drum as the others are in awesome shape is that it had a little lip on it and DOT frowns on that. I will check the out of round issue and will check out the slack adjuster very closely.
  7. allan5oh
    Jan 6, 2010
    1,557
    Thanks Received:
    556
    Winnipeg, mb
    It's not the slack itself. It's the bushing where the s cam rides.
  8. Powder Joints
    Sep 25, 2007
    7,939
    Thanks Received:
    8,277
    Rosamond, SoCal
    Slack Adjuster is over adjusting. Replace it. Maybe the bushing is contributing, I'd replace the both of them.
  9. daf105paccar
    Apr 15, 2012
    6,564
    Thanks Received:
    7,293
    I have to ask this.
    How much is a new drum?
  10. SHC
    SHC Spoiled Rotten Brat O/O
    Feb 26, 2011
    8,484
    Thanks Received:
    7,047
    Westville, IN
    Maybe it's got Alaskan Moose Hair stuck in it ???? LOL
    I second the valve or maybe the slack adjuster is going bad.
