Bridge capacities
Discussion in 'Questions From New Drivers' started by Bdog, Apr 23, 2017.
  1. Bdog
    Bdog Road Train Member
    Nov 6, 2014
    1,057
    Thanks Received:
    877
    What kind of safety factor is there in these ratings? If it is in a two lane road does the posted number assume two trucks going the opposite could be on it at once?
    I need to go to a location on Monday and I have thoroughly scouted it out in a pickup and there is no possible way to get there without going over this bridge on a two lane road that is posted 20 ton limit. I weigh 32 tons. Legally I know I am not supposed to go across it but if I wait and make sure I am the only vehicle on it I should be ok practically speaking right? I don't want go crashing into the creek but I need to get through here.
    BUMBACLADWAR Thanks this.
  2. BigTennOTR
    BigTennOTR Medium Load Member
    Dec 5, 2016
    625
    Thanks Received:
    766
    Tenn
    Bridges can hold 3 times what they are marked for? Think thats correct...but if that dang thing fails while your on it....its.gonna be a really bad day.......really bad....
    I remember a lady got jail time for collapsing a historic bridge somewhere due to ignoring the sigbs
    Bdog Thanks this.
  3. Chinatown
    Chinatown Road Train Member
    Aug 28, 2011
    74,699
    Thanks Received:
    169,846
    Henderson, NV & Orient
    Other trucks must use that bridge to reach the customer.
    There's one in Arkansas I had to cross often and it was the only way to reach the customer without going a couple hundred miles out of the way. The sign has 20K limit and I was always in the 60K to 70K range. I saw logging trucks cross it and other tractor trailers, so I didn't worry about it.
  4. BigTennOTR
    Dec 5, 2016
    625
    Thanks Received:
    766
    Tenn
    Just hit it fast....thats what i always do!
    Redtwin and Chinatown Thank this.
  5. Bdog
    Nov 6, 2014
    1,057
    Thanks Received:
    877
    Yes that was a 6 ton bridge and she was 40 tons. Over six times the limit.
  6. Bdog
    Nov 6, 2014
    1,057
    Thanks Received:
    877
    No customer per say. This is a very rural area and I am headed to a jobsite and the only truck there.
    Lepton1 Thanks this.
  7. BigTennOTR
    Dec 5, 2016
    625
    Thanks Received:
    766
    Tenn
    6 tons....40 tons.... same thing right?!
  8. BigTennOTR
    Dec 5, 2016
    625
    Thanks Received:
    766
    Tenn
    I honestly think youll be fine.....if engineers just built.that bridges to hold exactly what the sign says....there would be bridges down every where...
    Its definitely built.for twice its weight and your not even that
  9. Powder Joints
    Sep 25, 2007
    7,663
    Thanks Received:
    7,744
    Rosamond, SoCal
    Do what you will, but I would not cross it.
    not4hire and JReding Thank this.
  10. Chinatown
    Aug 28, 2011
    74,699
    Thanks Received:
    169,846
    Hit it fast and jammin' gears!
    BigTennOTR Thanks this.
