Broken hub tabs
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Socal Xpress, Sep 21, 2016.
  1. Socal Xpress
    Dec 6, 2014
    1,855
    Thanks Received:
    1,958
    Los Angeles, Ca
    Would this be an OOS violation? Missing lugs and loose lugs yes of course OOS. Unless the rim is cracked why would they have to replace it?
    I think this shop pulled a fast one on this very green individual. He should have done a better job on his pre trip to catch the loose lugs. He makes it seem like the shop was protecting him from a castrophic failure of the hub assembly. Am I wrong or was this good practice by this shop?
  2. purpleprime
    purpleprime Medium Load Member
    May 30, 2013
    681
    Thanks Received:
    720
    spickard, mo
    I would want the rim replaced I'm sure the holes are egg shaped now it will never ride true
  3. GrapeApe
    GrapeApe Road Train Member
    Jan 7, 2013
    2,215
    Thanks Received:
    2,211
    Why do you think the shop pulled a fast one? The hub tabs are broken, so it needs a new hub. The rim also needs to be replaced, the lug holes and center hole is damaged so it will never ride true even with a new hub.
    This driver is lucky that the tire did not fall off and no reputable shop would tell him it's OK to keep running with that hub or rim.
    The only fast one I see is trying to charge $439 for a standard Alcoa wheel, they're under $300 at most parts places.
  4. little cat 500
    Jan 17, 2010
    2,055
    Thanks Received:
    1,100
    Abbottstown PA
    if it's not an OOS it should be there's no way that thing ride's right
  5. AModelCat
    29,390
    Thanks Received:
    161,293
    That rim is done. Wheel probably wasn't torqued correctly, causing the lugs to back off. Then because the rim was free to move, it beat the centering tabs off the hub and chewed the rim up.
  6. Ezrider_48501
    Apr 2, 2011
    3,845
    Thanks Received:
    5,133
    bismarck, nd
    first time the camera panned at the rim i could tell the rim and the hub are both toast.
    Cottonmouth85 Thanks this.
  7. Cottonmouth85
    Cottonmouth85 Bad Influence
    May 3, 2012
    2,637
    Thanks Received:
    8,701
    Floresville, Tx
    If you don't know how to pretrip or drain the air system perhaps truck ownership is not the right move.
    Oooo $1.74 a mile.... yay!
    AModelCat Thanks this.
  8. cjb logistics
    cjb logistics Heavy Load Member
    Aug 13, 2016
    766
    Thanks Received:
    643
    Liberal Ks
    Yes I would also
  9. 6wheeler
    6wheeler Road Train Member
    Aug 30, 2009
    2,696
    Thanks Received:
    4,774
    Here is what I would have done if it was my own personal truck.
    Move that rim to the drive axles, and bring one of the drives up to the front.
    That style of rim is called hub piliot, it centers it self by the hub, not by the lug nuts. From what I could see in the video, that rim was still good. Everything else needed to be replaced. Studs, and hub.
    I worked in the truck tire business for 7 years both highway, and off road heavy equipment.
    Socal Xpress Thanks this.
  10. GrapeApe
    Jan 7, 2013
    2,215
    Thanks Received:
    2,211
    The rim is damaged at the center hole too. It could be mounted on an inner drive if it was positioned to get the tabs on an unworn part of it for a temp fix to save a tow, but it still needs to be replaced.
