Bunk Heater shutting off in the middle of the night
Discussion in 'Questions From New Drivers' started by DirtyhandsMcgee, Jan 14, 2018.
  1. DirtyhandsMcgee
    DirtyhandsMcgee Light Load Member
    Oct 30, 2017
    71
    Thanks Received:
    79
    It shuts off after I fall asleep and I wake up to a 15 degree truck. I know it's because the battery is getting too far drained. My question is, is this a common thing? Or can most trucks run them all night?
  2. craig_sez
    craig_sez Road Train Member
    Sep 5, 2013
    5,564
    Thanks Received:
    2,709
    novascotia,Canada
    Maybe batterys are weak,maybe battery connections are dirty...But the colder it hets the harder it is on batterys..Most times mine will shut off after about 6 hrs when really cold..I usually crank the heat b4 bed to warm the bunk and close the curtains that seperate bunk and cab,less space to heat..I also unplug my cooler and turn off what doent need to run....
    But to answer your question,yes it does happy and for a reason..You may wake up to a cold trk but there is still enuf power in the batterys to start it..
    Oh and use more blankets,create a better seal under the bunk and around doors and windows and those crappy vents...I was looking for somethin today under my bunk from outside..I noticed i could see in the cab....Ill be sealing that up with some foam tape..
    Tb0n3 and DirtyhandsMcgee Thank this.
  3. IluvCATS
    IluvCATS Road Train Member
    Dec 1, 2014
    4,091
    Thanks Received:
    8,976
    Seattle, WA
    I just went thru this. I had 3 out of 4 batteries were dead. Once my batteries were replaced and I had a annual service done at Thermo King, it’s awesome now.
    DirtyhandsMcgee Thanks this.
  4. IluvCATS
    Dec 1, 2014
    4,091
    Thanks Received:
    8,976
    Seattle, WA
    The cold killed my already aged batteries.
  5. craig_sez
    Sep 5, 2013
    5,564
    Thanks Received:
    2,709
    novascotia,Canada
    Cold does it to all normal batterys...Normal use kills batterys over time cause you loadem upand run them down..They dont handle it like deep cycles do..
    DirtyhandsMcgee and IluvCATS Thank this.
  6. IluvCATS
    Dec 1, 2014
    4,091
    Thanks Received:
    8,976
    Seattle, WA
    I like to run my vacuum, tv, and microwave at the same time. Sorta a cook-n-clean-n-tv binge. Don’t know why I had battery issues. :)
    AJ10036 and RedRover Thank this.
  7. driverdriver
    driverdriver Road Train Member
    May 30, 2011
    4,254
    Thanks Received:
    5,282
    Either the batteries or they're not resetting before you go to sleep.
    Espars are usually set to a 10hr run time.
    I always turn mine off and back on before I actually turn off the lights and tv.
  8. z32sean
    z32sean Light Load Member
    Aug 9, 2016
    110
    Thanks Received:
    179
    Middle Tennessee
    My Apu and bunk heater run separately so I can run one without the other. On real cold nights I will run the Apu with the air going, this allows the batteries to get a charge while the heater is running.
  9. Purree
    Purree Bobtail Member
    Jan 14, 2018
    33
    Thanks Received:
    19
  10. Purree
    Jan 14, 2018
    33
    Thanks Received:
    19
    Is it an APU or the dashboard heater while idling?
