c13 keep it or swap it
Discussion in 'Peterbilt Forum' started by dblaz18, Sep 12, 2014.
  1. dblaz18
    dblaz18 Bobtail Member
    Sep 11, 2014
    Thanks Received:
    Im no truck driver just a toy hauler but I bought a 2005 387 pete with a c13 with known problems blown headgasket possibly cracked head but the price was right so i got it after it is ran it will fill one of the rear cylinders with water when parked. after reading some good and also alot of bad it has me thinking of swapping engines I konw of a international with a ddec iii it I can buy for $4000 dollars complete no title for the truck has 400,000 miles on it I know the wirinh harnass is like 2500 dollars to do swap My trailer is like 25000 lbs loaded so power not a big issue but i think the detroit is rated higher than the c13 anyways what are your guys thoughts on the swap Thanks dave
  2. Lostkeys
    Lostkeys Heavy Load Member
    Jan 8, 2011
    903
    Thanks Received:
    6,243
    Archbold,OH
    If the Detroit is a good motor, I would swap the engine and not look back.
  3. maggard359
    maggard359 Medium Load Member
    Nov 20, 2013
    476
    Thanks Received:
    413
    Florida
    The detroit is a very good motor, but 6500 and your labor would almost rebuild your c13 if you do it yourself and you would know what you have. You never really know how long the detroit will last.
  4. Mooose
    Mooose Light Load Member
    Apr 13, 2014
    161
    Thanks Received:
    61
    Sherwood Park,AB
    Yep I agree, and I hope the rest of the truck is still operational, toy hauler or not 25k is a lot of weight and I personally wouldn't be messing around with stuff, how's the brakes, transmission, diffs, steering/king pins? Between the tractor and trailer your a 40k plus missile coming down the highway, hope you aren't in over your head. Personally "price was right" because nobody else thought it was worth the risk, sorry me included.
  5. dblaz18
    Sep 11, 2014
    Thanks Received:
    I have been pulling with heavy trucks for 15 years just not my living believe me the truck will be 100% safe and will pass dot anywhere probably be safer than a lot of junk on the road thanks for replies about the engine question
  6. dblaz18
    Sep 11, 2014
    Thanks Received:
  7. GrapeApe
    GrapeApe Road Train Member
    Jan 7, 2013
    2,215
    Thanks Received:
    2,211
    There is a lot to consider, I'd prefer a Series 60 over the C13, but do your research and compare costs. Not just the wiring, you'll have to deal with the plumbing (radiator, CAC, air cleaner & exhaust are all going to be a little different). Also consider any legal issues you might run into, many states do not approve of putting an older engine in. Whether or not this is a problem depends on a lot of things, but some shops wont even work on it, which could be a problem, maybe not.
    $2500 + 4000 for the other truck, I can see this running close to $10,000 by the time your done, the nickle & dime stuff adds up real quick. So wiegh out the options on what it'll cost to fix what you have and what it will really take to swap.
