C15 Cat wont start
Discussion in 'Trucks [ Eighteen Wheelers ]' started by silver dollar, Nov 7, 2012.
  1. silver dollar
    silver dollar Medium Load Member
    Jan 31, 2009
    481
    Thanks Received:
    210
    Central North Carolina
    Somebody help me please!
    Truck: 02 Int'l 9400i
    Engine: Cat C15 6NZ
    Problem: Wont start and keep running.
    So here's the deal. truck ran great all week. I got in Friday afternoon, parked it 'til Monday morning. When I tried to start it, it wouldn't. Engine would crank over fine, but wouldn't fire. I gave it a shot of starting fluid and it would run til it was gone and quit. I removed the spin on fuel filter and replace it with a spin on block off plate, drained a bit of fuel from the Davco (no water). Gave it a few pumps of the primer pump, and another shot of ether and she fired and ran. I drove about 100 miles round trip to deliver a load. It did seem a little short of power, but ran fine; and had no problem starting after sitting for two hours while getting unloaded.
    After sitting from Monday afternoon til Wednesday morning, the same thing: would crank over, but would not fire up. There was fuel in the Davao so I gave it a shot of ether. It ran on the ether and quit. I gave a few strokes on the primer pump and another shot, and it fired and ran fine. I let it idle for about 20 min then shut it off and change the oil. After which I started it and let it run for a couple of min to check for leaks. I shut it off, check the oil, and was going to add a gallon of Lucas. I restarted it (I always have the engine running while adding Lucas) It ran for about 45 seconds, started to skip and shut down. I stroked the primer pump, again, gave it a shot, again, it fired and ran for about a min and shut down; again.
    My problem seems to be fuel related can someone help me please. Where do i start to trouble shoot? What do I look for? (Fuel tanks are 1/2 full)
  2. Licensed to kill
    Licensed to kill Heavy Load Member
    Dec 31, 2010
    830
    Thanks Received:
    2,435
    Alberta
    Sounds like you may have a leak somewhere between the tanks and the lift pump (suction side). Could be as simple as a loose fuel line fitting. Put a wrench on each one and make sure they are tight.
    Vampire and silver dollar Thank this.
  3. silver dollar
    Jan 31, 2009
    481
    Thanks Received:
    210
    Thanks for the reply. If there is, say a loose fitting, on a suction line would I see evidence of leaking fuel, or will it just suck air. I know this question is elementary, but i want to know what to look for also when i crawl around under this beast.
  4. Licensed to kill
    Dec 31, 2010
    830
    Thanks Received:
    2,435
    Alberta
    You wont likely see any leaking fuel. It sounds to me that you may have had a slight leak, just enough to cause it to lose prime over a day or two that has developed into a bigger leak causing it to suck enough air while running to cause it to stutter and shut down after just a minute or so. A loose fitting shaking looser could explain this progression. I'ld start with the easy ones (at the lift pump) and work back. No point climbing around under the truck if its at a filter housing or the lift pump.
    silver dollar and Vampire Thank this.
  5. Cummins600
    Cummins600 Bobtail Member
    May 18, 2011
    26
    Thanks Received:
    8
    Pa
    If you see any dirt on the lines that should be where the fuel is leaking from. Good luck.
    silver dollar Thanks this.
  6. underpsi
    underpsi Road Train Member
    Sep 18, 2008
    1,266
    Thanks Received:
    292
    Toronto, Ont
    Sounds like it could be your check valve getting weak.
  7. Licensed to kill
    Dec 31, 2010
    830
    Thanks Received:
    2,435
    Alberta
    Check valve would be the likely cause for the "won't start after a day or so" but shouldn't account for the "starts, runs for a minute or so then quits" and does this twice back to back. All the valves do is hold pressure/prime when it's not running.
  8. silver dollar
    Jan 31, 2009
    481
    Thanks Received:
    210
    Thanks, With what you and Underpsi said, this is starting to make sense to me now. I'll let you know tomorrow.
  9. silver dollar
    Jan 31, 2009
    481
    Thanks Received:
    210
    thanks, I'll check this too.
  10. western diesel & performa
    western diesel & performa Bobtail Member
    Nov 7, 2012
    10
    Thanks Received:
    If the hand primer was soft it s draining fuel from the check valve p/n 281-2725 easy to change this is a common thing swap it out bleed the fuel good As new
