CA Carrier: Do BIT 90 day inspections count for the Annual DOT inspection required federally?
Discussion in 'Questions To Truckers From The General Public' started by speedstickman, Dec 27, 2023.
  1. speedstickman
    speedstickman Light Load Member
    Jul 10, 2012
    66
    Thanks Received:
    20
    I am a CA carrier. I get the BIT inspection done every 90 days (as required by CA law). Is the annual DOT required by federal law the same as the BIT inspection? or do I need to get a separate DOT inspection every year to fulfill this requirement? Thank you
  2. LOTSO
    LOTSO Heavy Load Member
    Mar 28, 2023
    830
    Thanks Received:
    2,002
    B.I.T. is "Biannual Inspection of Terminal" CHP doesn't even do those anymore. They adopted the FMCSA protocol. Basically, after your initial New Entrant Inspection, unless you screw up, you won't hear from them again. I don't think I've had a "B.I.T." in 15 years. You are doing a "90 Day Inspection" which can be done by the company owner or companies mechanic, if they had one, which, I believe is required at the Federal level also. The "Annual D.O.T. Inspection" has to be done by an independent shop. Cannot be performed by the company's mechanics. This inspection report must be carried in the vehicle ready to show L.E. Someone else here might know more though.
    Malou Thanks this.
  3. Big Road Skateboard
    May 2, 2021
    6,668
    Thanks Received:
    37,497
    I don't think they replace a federal DOT. But, a DOT inspection can be performed by anybody, through either FMCSA certification or self certification. Not saying any swingin Jimmy is certified, but if you are, you can do your own.
    If you're leased on somewhere, i doubt they will accept you doing your own, and would require a shop.
