Can I torque my wheels with an impact?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Josiah Harder, May 9, 2023.
  1. Josiah Harder
    Josiah Harder Light Load Member
    Sep 23, 2022
    120
    Thanks Received:
    73
    If I have an impact wrench that can be set to 600 ft/lbs is that okay to use to torque and retorque my wheels? Or will I risk damaging something since they are normally only 500 ft/lbs.
  2. Big Road Skateboard
    May 2, 2021
    6,316
    Thanks Received:
    35,073
    Just cause an impact says 600ft lbs, you won't see that.
    There's a reason tire guys use 1" guns. I run mine down with a drop of oil on threads, torque to 500
  3. Goodysnap
    Goodysnap Road Train Member
    Jul 12, 2017
    3,724
    Thanks Received:
    9,054
    You can tighten them with an impact but they will not be “Torqued”.
  4. Josiah Harder
    Sep 23, 2022
    120
    Thanks Received:
    73
    If the impact goes to 600 ft/lbs they should be right. I'm more worried about over torquing
    OLDSKOOLERnWV Thanks this.
  5. Goodysnap
    Jul 12, 2017
    3,724
    Thanks Received:
    9,054
    Yea…. That’s not how it works.
    If you’re truly worried about over torque you should be using a torque wrench.
  6. Rideandrepair
    Aug 8, 2015
    17,357
    Thanks Received:
    56,318
    Can’t trust the claimed torque ratings on the guns. Most are supposedly break away ratings. Either way there’s no actual rating system. The only way to know is compare the performance against a torque wrench. I’d almost bet money that 600lb rating will yield an actual 300-400lb at best. Test results are all over the board on air guns rated and actual torque.
  7. AModelCat
    29,342
    Thanks Received:
    160,732
    Just because it says 600 ft-lbs doesn't mean ####.
    Its not a calibrated torquing tool. Cut and dry, no way around it. Buy a torque wrench or go to a tire shop.
  8. Tb0n3
    Tb0n3 Road Train Member
    Oct 5, 2012
    4,635
    Thanks Received:
    9,327
    Earth
    Look up torque sticks. I'm not sure they go up to the right amount, but if they do it'll get pretty close when used properly.
    RockinChair and Josiah Harder Thank this.
  9. Tumbleweed TowMan
    Tumbleweed TowMan Medium Load Member
    Jun 22, 2022
    390
    Thanks Received:
    1,714
    A decent torque wrench just isn't that expensive to NOT have one.
    Hell, I bought a nice one when it was needed for just my RV front hubs replacement.
    And you say the impact will tap out at 600lbs, but your component calls for only 500lbs .... do you not see the issue there?
    God prefers Diesels and JoeyJunk Thank this.
  10. AModelCat
    29,342
    Thanks Received:
    160,732
    I'd zip up telehandler wheels (same exact nuts and studs as a truck) with my 1,250 ft-lb rated 1/2" impact and they'd still budge slightly with a torque wrench set to 500 ft-lbs.
