Can't find my old thread.
Discussion in 'Ask An Owner Operator' started by feldsforever, Nov 28, 2021.
  1. feldsforever
    feldsforever Road Train Member
    Nov 22, 2019
    1,453
    Thanks Received:
    1,440
    Usally the search bar works decent. Not sure if im spelling the title wrong or what have you.
    Its the truck stop diagnosis. Thread. What I'm going to add is how to narrow down a anti freeze leak.
  2. TROOPER to TRUCKER
    TROOPER to TRUCKER Anything Is Possible
    Dec 15, 2014
    7,673
    Thanks Received:
    12,733
    Charlotte, NC
    Go to your profile and go to your content and if it’s still here it will be on that list.
    feldsforever and Grumppy Thank this.
  3. Chinatown
    Chinatown Road Train Member
    Aug 28, 2011
    75,033
    Thanks Received:
    171,100
    Henderson, NV & Orient
  4. NYStarcar
    NYStarcar Light Load Member
    Oct 6, 2020
    249
    Thanks Received:
    595
    In a van down by the river
    What have you got going on with the coolant leak?
  5. feldsforever
    Nov 22, 2019
    1,453
    Thanks Received:
    1,440
    @Chinatown . I must uave titled it different than what I remember. I went three pages back and didn't see it. I think I'm going to start one called. Help me fix this.
    @NYStarcar
    I'm not sure where its going. I've looked all over the engine. It's not in the oil which I know is a plus. But I'm losing about 3/4th gallon every 8 or 9 days. Some one suggested looking at the engine at night with a flash light. But I'm not sure how that would help.
  6. D.Tibbitt
    21,791
    Thanks Received:
    149,022
    Do u have a cummins? How many miles on the engine? If no visible leaks, and not in the oil. If you have a cummins they a notorious for egr coolers going bad and drinking the coolant around 500k miles or so. Thats quite a bit of coolant to be using but no leaks. Its burning off somewhere.
    feldsforever Thanks this.
  7. ProfessionalNoticer
    Apr 25, 2021
    2,941
    Thanks Received:
    7,858
    Do an oil sample.
    D.Tibbitt and feldsforever Thank this.
  8. feldsforever
    Nov 22, 2019
    1,453
    Thanks Received:
    1,440
    @D.Tibbitt DD13
    @ProfissionalNoticer i will this next oil change
    ProfessionalNoticer and D.Tibbitt Thank this.
  9. Siinman
    Siinman Road Train Member
    Mar 5, 2017
    5,306
    Thanks Received:
    13,445
    Kansas City, MO.
    Did it end up in your Fuel water separator? I had this happen earlier this year but it drank the coolant.
    D.Tibbitt Thanks this.
  10. Diesel Dave
    Jan 20, 2010
    8,739
    Thanks Received:
    25,141
    Hesperia, Ca.
    Check your transmission fluid level, if it pours out from the side fill plug, you have your answer, it will be the “Transmission Cooler”. I was losing coolant also, I had all the signs, I was pushing gear oil thru the breather first, I extended the breather with a hose, after a week or so, I started leaking gear oil thru the front input shaft(seal). I finally told the shop to drain all the transmission fluid and bypass the transmission cooler. My problem was solved. No more coolant loss.
