Cant get SWR below 3
Discussion in 'CB Radio Forum' started by truckerdan90, May 26, 2014.
  1. truckerdan90
    truckerdan90 Bobtail Member
    Feb 13, 2012
    31
    Thanks Received:
    4
    The stock antenna system in my 2012 Pete 386 is crap (at least I think that's why I have to be within about 15 yards of another radio to be able for them to hear me). I can hear other guys decently well when they are a ways out. I have been using a 40 dollar cobra radio but just put my 29 LTD classic back in. I also just installed a 4' Wilson fiberglass tunable tip antenna on the edge of the mirror mount and ran a separate heavy duty 18' Wilson Coax thru the door jamb. SWR on channel 1 is about 3 and on channel 40 is about 3.5. No matter how I adjust the tip I cannot get SWR below 3. From my research it seems that I need a better ground plane (connections are good and no pinched coax). Would getting one of the 4' Firestik No-Ground-Plane antennas be good or should I try a magnetic mount and put it on the roof? Not sure if base/top/center loaded are better as far as range.
  2. Gordon A
    Gordon A Medium Load Member
    Jul 22, 2013
    384
    Thanks Received:
    345
    I always had better luck with Francis antennas. for store bought stuff.
    If you aren't afraid to spend some money on a very good antenna go to Tulos electronics out of Star MS. I bought mine back in the early 90's.Troy Tulos will set every thing up and I guarantee you will have an above average set up. He builds antennas for nearly every kind of set up. from the ground up.
    99% of high SWR problems is bad grounding.
    Run a braided ground strap from antenna mount to door ground then to cab then to chassis. Each one as short as possible. It could be your mic is going bad. If your radio is hearing but not talking.
    If the coax is running though the door jamb you may be pinching the foam in side the coax and allowing current to flow down the out side of the coax. You may not see a distinct pinch with door open.
    I do not run truck stop coax as it is for the most part junk. Use some RG 58U . Same as hams run .
    It is not the radio that gets out but your antenna that does it. Coax is part of the antenna system. Assuming you run one antenna and your radio is 4 watts out your getting 4 out the antenna. Co phase is two antennas and each one is sending out 2 watts.
    http://www.stargun.cc/
    601-845-7099
  3. delta5
    delta5 Road Train Member
    Sep 9, 2010
    1,193
    Thanks Received:
    7,404
    SWR that high means there is no ground plane for the antenna...
  4. Xcis
    Xcis Medium Load Member
    Jul 9, 2008
    498
    Thanks Received:
    270
    Bridgeport, Pa
    You seem to have an antenna ground plane problem since your SWR reading is 3.0 or higher. Do a search on antenna ground plane. This has been covered to death in previous topics. There are a number of topics that should give you an idea of what you should do to correct things.
    I would not change antenna or coax until you fix the antenna ground plane. Once your antenna ground plane problem is solved, you maybe satisfied with what you alreadly have. If not satisfied, I would recommend that you have the radio checked by a competent cb tech to see if you power transistors [what some call the "finals"] have been damaged. I hope that is not needed; but, using a radio with an excessively high SWR reading can affect the power transistors that are in the radio.
    .Personally, I would crack the driver's window and run a short length of coax from the antenna mount through the window and up to the radio. But then I would keep the driver's door closed and go in and out of the passenger door.
    .When you are running just one antenna, you require 50 ohm coax. Either RG-58 or RG 8 coax; your choice. There is really no need to use really expensive coax unless you are running a high power setup. For a stock radio either one will work for you.
  5. Getsinyourblood
    Getsinyourblood Road Train Member
    Jul 5, 2014
    1,273
    Thanks Received:
    1,803
    Retired. North Texas
    I would say bad ground. A lot of the new trucks have plastic mirrors, not good for grounding. I know some guys who run a ground from the antenna to the frame of the truck. Not the easiest thing to do, but well worth it. Maybe a CB shop could do it for you.
  6. Gordon A
    Jul 22, 2013
    384
    Thanks Received:
    345
    If you have some old RG 8 laying around just strip the outer cover off. Use the shield braid . Cut off several lengths. Put a lug on each end. put ground from antenna to door bolt. door to chassis and chassis (cab)to frame. The shorter the better. Fairly easy to do. I had the same issue with my Lil Tarheel II on a Freightliner . That is how i corrected it. Now very good SWR.
  7. mike5511
    mike5511 Road Train Member
    May 15, 2011
    3,154
    Thanks Received:
    1,544
    NW Arkansas
    best advice......imo!
  8. Powder Joints
    Sep 25, 2007
    7,906
    Thanks Received:
    8,211
    Rosamond, SoCal
    Sounds like coax issues.
  9. Gordon A
    Jul 22, 2013
    384
    Thanks Received:
    345
    Truck manufacturers use really bad coax that is designed for receiving and not transmitting. I had to re do the coax in every truck I drove. it is the same coax that the AM FM radio uses. at least that is how it used to be. Manufacturers may have had an awakening since then. No matter what they use today it still is not very good. .
  10. 43mack
    43mack Bobtail Member
    Apr 20, 2014
    18
    Thanks Received:
    4
    with the coax disconnected from the base of the antenna check for continuity from the antenna mount to the frame of the vehicle, no continuity not gonna work
